[Mapserver-users] (newbie): Win32 Apache error
whencallingMapserv.exe
Balkanu GIS
gis at balkanu.com.au
Tue Jan 27 01:04:43 EST 2004
Derr...
Original error was a problem with the path. Fixed path by changing the line
in demo_init.html from "/maps/ms_demo/demo_init.html" to
"../maps/ms_demo/demo_init.html" and am now presented with the following
error:
msLoadMap(): Unknown Identifier. Parsing Error near (SHADESET):(Line 7)
Either I am over one hurdle and am at another, or I have specified the path
incorrectly again.
Any thoughts? Please forgive my cluelessness!
Yuri
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Balkanu GIS
Sent: Tuesday, 27 January 2004 13:22
To: nacional at cbs.umn.edu; 'Tyler Mitchell'
Cc: Mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] (newbie): Win32 Apache error
Thank you again Tyler & Pericles,
I changed "Options All MultiViews" to "Options ExecCGI" without apparent
success, but commenting out the <IfModule></IfModule>... block did the
trick! The unfortunate thing is that I don't know why...
Nevertheless Mapserve.exe was able to respond. Having opened
".../ms_demo/demo_init.html" and clicked on "Initialize" to send the
starting parameters to MapServer, I am presented with the error:
"msLoadMap(): Unable to access file. (/maps/ms_demo/demo.map)"
I suppose this is most likely a permissions error, again probably a result
of my mauling of httpd.conf. The file is most certainly in that location,
but cannot be opened. I'm supposing that the function "msLoadMap()" is
contained in the MapServer application.
Should I be allowing localhost/127.0.01 access to "/maps/ms_demo/" through
httpd.conf?
-Yuri
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Pericles S.
Nacionales
Sent: Tuesday, 27 January 2004 07:55
To: Tyler Mitchell
Cc: Balkanu GIS; Mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] (newbie): Win32 Apache error when
callingMapserv.exe
Tyler,
Thanks for coming back to this. I found a few more inconsistencies with the
configuration file. Those last two lines might actually be ok--there might
be a beginning <IfModule mod_alias.c> tag somewhere above the beginning of
the snippet Yuri sent us.
What I would try then, Yuri, is comment out the <IfModule
mod_perl.c></IfModule> block:
<Directory "C:/phpdev/www/cgi-bin">
#<IfModule mod_perl.c>
# Sethandler perl-script
# PerlHandler Apache::Registry
# PerlSendHeader On
# </IfModule>
AllowOverride None
Order deny,allow
Allow from all
</Directory>
Oh, one more thing... Perhaps this is all you need to do. Change "Options
All MultiViews" to "Options ExecCGI". Hah! I just saw the line above. I
bet that's all you need to do.
-Perry
On Mon, 2004-01-26 at 14:10, Tyler Mitchell wrote:
> I'm always cutting/pasting apache.conf directory code, do his cgi-bin
> properties look good to go with executables?
> mapserver-users-admin at lists.gis.umn.edu wrote on 01/23/2004 12:09:29
> AM:
> > Yuri,
> > Check the last two lines of your apache config snippet...
> > > </Directory>
> > > </IfModule>
> > If this is how they appear in your config file, switch them.
> > </IfModule>
> > </Directory>
> > This could be the cause of your problem.
> > > If not, something is wrong with your executable. But then again
> > > it
> could
> > > just
> > > be permission problems. Or perhaps you've locked down your
> > > CGI-BIN directory so that only scripts with certain extensions
> > > would run?
> > -Perry N.
> > "He's no geek.His tan's too good." -Benjamin Choate
> > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
