[Mapserver-users] geotiff output problem
Frank Warmerdam
warmerdam at pobox.com
Tue Jan 27 13:30:49 EST 2004
Aaron D. Hunt wrote:
> I am trying to get mapserver to output geotiffs. When I do so the tiff
> is made fine but the geo in-coding is blank (see listgeo out put below).
> I have mapserver 4.0.1 with gdal-cvs-031112, tiff-v3.6.0 and
> libgeotiff-1.2.1 on redhat 9.0 (configure call below). The perl script
> and Map file I am using is also bellow. Does anyone have any ideas.
Aaron,
What you did seems fine. It is possible that the "init=epsg:26915" isn't
being expanded properly though even then the coordinates should have been
written. I tried running shp2img on the following map file and produced a
GeoTIFF file with coordinates and a coordinate system.
MAP
NAME "w2qpgi5qsg4k"
DEBUG on
SIZE 400 400
EXTENT -6500000 -6500000 6500000 6500000
OUTPUTFORMAT
NAME GT
DRIVER "GDAL/GTiff"
IMAGEMODE RGB
END
LAYER
NAME "world"
TYPE Raster
STATUS default
DATA "/home/warmerda/public_html/world.tif"
PROCESSING "DITHER=YES"
PROJECTION
"proj=latlong"
END
END
#PROJECTION
#"proj=ortho"
#"lat_0=0.0"
#"lon_0=0.0"
#"x_0=0.0"
#"y_0=0.0"
#END
PROJECTION
"init=epsg:26915"
END
END
warmerda at gdal2200[242]% gdalinfo out.tif
GDAL: GDALOpen(out.tif) succeeds as GTiff.
Driver: GTiff/GeoTIFF
Size is 400, 400
Coordinate System is:
PROJCS["NAD83 / UTM zone 15N",
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.2572221010042,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6269"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4269"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-93],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","26915"]]
Origin = (-6500000.000000,6500000.000000)
Pixel Size = (32500.00000000,-32500.00000000)
Corner Coordinates:
Upper Left (-6500000.000, 6500000.000) ( 95d47'40.98"W,280d 4'9.61"N)
Lower Left (-6500000.000,-6500000.000) ( 95d47'40.98"W,280d 4'9.61"S)
Upper Right ( 6500000.000, 6500000.000) ( 86d 6'45.06"E,101d28'3.37"N)
Lower Right ( 6500000.000,-6500000.000) ( 86d 6'45.06"E,101d28'3.37"S)
Center ( 0.0000000, 0.0000000) ( 97d29'19.48"W, 0d 0'0.01"N)
Band 1 Block=400x20 Type=Byte, ColorInterp=Red
Band 2 Block=400x20 Type=Byte, ColorInterp=Green
Band 3 Block=400x20 Type=Byte, ColorInterp=Blue
GDAL: GDALClose(out.tif)
GDAL: GDALDeregister_GTiff() called.
I really don't know what is going wrong at your end. You could try
updating to more recent Mapserver versions, but I don't really see that
this should be needed. Could you try running shp2img on your .map and
verify that this also exibits the same problem?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
