[Mapserver-users] geotiff output problem
Aaron D. Hunt
hunt at zedxinc.com
Tue Jan 27 15:38:35 EST 2004
I worked when I used shp2img. Is there any reason it is not working in the
script?
----- Original Message -----
To: "Aaron D. Hunt" <hunt at zedxinc.com>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, January 27, 2004 1:30 PM
Subject: Re: [Mapserver-users] geotiff output problem
> Aaron D. Hunt wrote:
> > I am trying to get mapserver to output geotiffs. When I do so the tiff
> > is made fine but the geo in-coding is blank (see listgeo out put below).
> > I have mapserver 4.0.1 with gdal-cvs-031112, tiff-v3.6.0 and
> > libgeotiff-1.2.1 on redhat 9.0 (configure call below). The perl script
> > and Map file I am using is also bellow. Does anyone have any ideas.
> Aaron,
> What you did seems fine. It is possible that the "init=epsg:26915" isn't
> being expanded properly though even then the coordinates should have been
> written. I tried running shp2img on the following map file and produced a
> GeoTIFF file with coordinates and a coordinate system.
> MAP
> NAME "w2qpgi5qsg4k"
> DEBUG on
> SIZE 400 400
> EXTENT -6500000 -6500000 6500000 6500000
> OUTPUTFORMAT
> NAME GT
> DRIVER "GDAL/GTiff"
> IMAGEMODE RGB
> END
> LAYER
> NAME "world"
> TYPE Raster
> STATUS default
> DATA "/home/warmerda/public_html/world.tif"
> PROCESSING "DITHER=YES"
> PROJECTION
> "proj=latlong"
> END
> END
> #PROJECTION
> #"proj=ortho"
> #"lat_0=0.0"
> #"lon_0=0.0"
> #"x_0=0.0"
> #"y_0=0.0"
> #END
> PROJECTION
> "init=epsg:26915"
> END
> END
> warmerda at gdal2200[242]% gdalinfo out.tif
> GDAL: GDALOpen(out.tif) succeeds as GTiff.
> Driver: GTiff/GeoTIFF
> Size is 400, 400
> Coordinate System is:
> PROJCS["NAD83 / UTM zone 15N",
> GEOGCS["NAD83",
> DATUM["North_American_Datum_1983",
> SPHEROID["GRS 1980",6378137,298.2572221010042,
> AUTHORITY["EPSG","7019"]],
> AUTHORITY["EPSG","6269"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4269"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",-93],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","26915"]]
> Origin = (-6500000.000000,6500000.000000)
> Pixel Size = (32500.00000000,-32500.00000000)
> Corner Coordinates:
> Upper Left (-6500000.000, 6500000.000) ( 95d47'40.98"W,280d 4'9.61"N)
> Lower Left (-6500000.000,-6500000.000) ( 95d47'40.98"W,280d 4'9.61"S)
> Upper Right ( 6500000.000, 6500000.000) ( 86d 6'45.06"E,101d28'3.37"N)
> Lower Right ( 6500000.000,-6500000.000) ( 86d 6'45.06"E,101d28'3.37"S)
> Center ( 0.0000000, 0.0000000) ( 97d29'19.48"W, 0d 0'0.01"N)
> Band 1 Block=400x20 Type=Byte, ColorInterp=Red
> Band 2 Block=400x20 Type=Byte, ColorInterp=Green
> Band 3 Block=400x20 Type=Byte, ColorInterp=Blue
> GDAL: GDALClose(out.tif)
> GDAL: GDALDeregister_GTiff() called.
> I really don't know what is going wrong at your end. You could try
> updating to more recent Mapserver versions, but I don't really see that
> this should be needed. Could you try running shp2img on your .map and
> verify that this also exibits the same problem?
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
