[Mapserver-users] WMS server image black padding and aspect
ratio
Eric Sokolowsky
eric.sokolowsky at gsfc.nasa.gov
Wed Jan 28 14:28:58 EST 2004
On Fri, 23 Jan 2004, Daniel Morissette wrote:
> Eric Sokolowsky wrote:
> > I am running mapserver 4.0.1 but this aspect also appears with the
> > version in CVS. I am using mapserver as a WMS server on a Red Hat Linux 9
> > system. When I request an image that is not the same aspect ratio as
> > the original image on the server, it seems that the image I get is
> > not stretched so that it fills the entire frame. The aspect ratio of the
> > original source is maintained and black bars either appear above and below
> > or else on both sides, similar to the effect of watching widescreen movies
> > on a regular TV. Is this the intended behavior, and if so, is there a way
> > to turn it off?
> The short answer is that MapServer doesn't support rendering maps with
> different X and Y scales. This is one of the only issues with MapServer
> before it passes all the OGC WMS tests.
This is most unfortunate. It is absolutely critical for my application
to allow this. Most of the images that I want to serve have different
X and Y scales, and it would be very difficult to rescale all of them.
Also, even if I rescaled all of the images, it would not solve the problem
of requesting a different aspect ratio bounding box.
Is there work being done to fix this problem? I am willing to jump into
the code to try and find a way to solve it, but I am not familiar with
the code and it may take me a while to get up to speed with it.
> For the long story, see the following thread in the archives:
> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00105.html
> Daniel
____ __ Eric Sokolowsky (GST) NASA Goddard Space Flight Center
/ __/__/_/__ Visualization Programmer Scientific Visualization Studio
/ __/ _/ / _/ 301.286.3751 Mailstop 935.0 Bldg 28 Rm E102
/___/_//_/__/ eric.sokolowsky at gsfc.nasa.gov Greenbelt, MD 20771
