[Mapserver-users] jBox ANNOUNCE
Richard Greenwood
rich at greenwoodmap.com
Wed Jan 28 14:40:19 EST 2004
Palanisamy, Giri wrote:
> HI Richard,
> How can I include the jBox.jar file, I have placed the jar file under
> C:\Inetpub\wwwroot\java\jBox\
> And in my demohtml file I call the applet as
> <applet codebase="/java/jBox" code="jBox.class" width="600" height="600"
> name="jBox.jar" MAYSCRIPT>
> </applet>
> (I also tried changing code="jBox.jar")
> I am getting the following applet load error
> load: class jBox.class not found.
> java.lang.ClassNotFoundException: jBox.class
> at
> sun.applet.AppletClassLoader.findClass(AppletClassLoader.java:153)
> Thanks for your time
> Giri
You need to add the following attribute into the the <applet> tag:
archive='jBox.jar'
For example:
<applet codebase='/java/jBox'
code='jBox.class'
archive='jBox.jar'
width=[mapwidth]
height=[mapheight]
name='jBox' MAYSCRIPT>
<param other parameters)>
</applet>"
The .jar file(s) should reside in the '/java/jBox' directory in this
example. The .class files no longer need to be on the server.
Regards,
Richard Greenwood
www.greenwoodmap.com
