[Mapserver-users] OGR unable to access datasource
Tyler Mitchell
TMitchell at lignum.com
Wed Jan 28 19:43:52 EST 2004
> Everytime I try to render the map I get the following error (the file is
> definitely there):
> msDrawMap(): Image handling error. Failed to draw layer named
'OGRPoints'.
> msOGRFileOpen(): OGR error. Open failed for OGR connection
> `c:\inetpub\wwwroot\MS_DEMO\ogr.ovf'. File not found or unsupported
format.
Are you confident that your version of OGR is updated enough - does it
include this virtual layer support? If so, then you should be able to use
the stand alone ogrinfo utility to test it first.
Tyler
