[Mapserver-users] OGR unable to access datasource
    Normand Savard
    nsavard at dmsolutions.ca
    Thu Jan 29 06:14:27 PST 2004
It looks like the same problem as Julien  Heryk had last week for MS
Access (0401/msg00533:
<http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00533.html>[Mapserver-users]
Re: VirtualSpatialData (OGR Connectiontype)).  I am able to reproduce it
with MS Access as well on Windows XP home edition.
Norm
Tyler Mitchell wrote:
>>Everytime I try to render the map I get the following error (the file is
>>definitely there):
>>  msDrawMap(): Image handling error. Failed to draw layer named
>'OGRPoints'.
>>  msOGRFileOpen(): OGR error. Open failed for OGR connection
>>`c:\inetpub\wwwroot\MS_DEMO\ogr.ovf'. File not found or unsupported
>format.
>Are you confident that your version of OGR is updated enough - does it
>include this virtual layer support?  If so, then you should be able to use
>the stand alone ogrinfo utility to test it first.
>Tyler
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
