[Mapserver-users] Re: [ms4w-users] mapserv_40.exe fails in featurequery
Paul Spencer
spencer at dmsolutions.ca
Thu Jan 29 07:30:20 EST 2004
Hagen,
this is a MapServer issue. Please address questions of this nature to
the mapserver-users mailing list to ensure the best possible chance of
response.
Cheers,
Paul
hpr wrote:
> Hi users,
> I'm a newbie in mapserver, therefore I'm using mapbender with my own data.
> If I try to query (identify) an element, then the querywindow is opened
> with the correct queryoutput
> but at the same time I get a window with the following message:
> german (original):
> "mapserv_40.exe hat Fehler verursacht und wird geschlossen.
> Starten Sie das Programm neu.
> Ein Fehlerprotokoll wird erstellt."
> english (translation):
> "mapserv_40.exe fails with errors, application is closed.
> Start the program again.
> An error-logfile is created"
> The error-log-file contains following message:
> "GET
> /cgi-bin/mapserv_40.exe?map=C:/ms4w/apache/htdocs/myapplication/myapp.map&&WMTVER=1.0.0&REQUEST=feature_info&
> LAYERS=Flaechen&STYLES=default&SRS=epsg:4326&BBOX=3506980.17,5818960,3510039.83,5820970&
> WIDTH=685&HEIGHT=450&FORMAT=PNG&TRANSPARENT=FALSE&BGCOLOR=0xffffff&
> QUERY_LAYERS=Flaechen&X=314&Y=143&INFO_FORMAT=text/html HTTP/1.1" 200 694
> If I delete the parameter "INFO_FORMAT=text/html" in the file mapJS.php,
> then the error is not occured
> but the output is only in text-Format without html-Tags.
> What can I do ?
> Hagen
|Paul Spencer spencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
