[Mapserver-users] Re: [ms4w-users] mapserv_40.exe fails in featurequery
Arnulf Christl
arnulf.christl at ccgis.de
Thu Jan 29 09:23:07 EST 2004
This is a multi-part message in MIME format.
--------------030803060303070306010800
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 7bit
this problem has been discussed in the German user list, I have attached
the answer from Till Adams.
in english:
You need a Mapserv v4.01 or prior to 3.6 -- all versions between 3.6x
and 4.0 hav a bug in the "GetFeatureInfo" request which causes this
error on MS machines
Regards, Arnulf.
Paul Spencer wrote:
> Hagen,
> this is a MapServer issue. Please address questions of this nature to
> the mapserver-users mailing list to ensure the best possible chance of
> response.
> Cheers,
> Paul
> hpr wrote:
>> Hi users,
>> I'm a newbie in mapserver, therefore I'm using mapbender with my own
>> data.
>> If I try to query (identify) an element, then the querywindow is
>> opened with the correct queryoutput
>> but at the same time I get a window with the following message:
>> german (original):
>> "mapserv_40.exe hat Fehler verursacht und wird geschlossen.
>> Starten Sie das Programm neu.
>> Ein Fehlerprotokoll wird erstellt."
>> english (translation):
>> "mapserv_40.exe fails with errors, application is closed.
>> Start the program again.
>> An error-logfile is created"
>> The error-log-file contains following message:
>> "GET
>> /cgi-bin/mapserv_40.exe?map=C:/ms4w/apache/htdocs/myapplication/myapp.map&&WMTVER=1.0.0&REQUEST=feature_info&
>> LAYERS=Flaechen&STYLES=default&SRS=epsg:4326&BBOX=3506980.17,5818960,3510039.83,5820970&
>> WIDTH=685&HEIGHT=450&FORMAT=PNG&TRANSPARENT=FALSE&BGCOLOR=0xffffff&
>> QUERY_LAYERS=Flaechen&X=314&Y=143&INFO_FORMAT=text/html HTTP/1.1" 200
>> 694
>> If I delete the parameter "INFO_FORMAT=text/html" in the file
>> mapJS.php, then the error is not occured
>> but the output is only in text-Format without html-Tags.
>> What can I do ?
>> Hagen
Content-Type: message/rfc822;
name="Attached Message"
Content-Transfer-Encoding: 8bit
Content-Disposition: inline;
filename="Attached Message"
Return-path: <mapbender-users-admin at lists.sourceforge.net>
Envelope-to: arnulf.christl at ccgis.de
Received: from proxy.dmz ([192.168.0.5] helo=vogon.ccgis.de)
by center.shared with esmtp (Exim 3.35 #1 (Debian))
id 1Al9ja-00039R-00
for <arnulf.christl at ccgis.de>; Mon, 26 Jan 2004 17:37:10 +0100
Received: from amavis by vogon.ccgis.de with virus-scanned (Exim 3.36 #1 (Debian))
id 1AlAGw-0005gw-00
for <arnulf.christl at ccgis.de>; Mon, 26 Jan 2004 18:11:38 +0100
X-Scanned-By: AMaViS-ng at Geo-Consortium Bonn
Received: from mail by vogon.ccgis.de with spam-scanned (Exim 3.36 #1 (Debian))
id 1AlAGR-0005fn-00; Mon, 26 Jan 2004 18:11:08 +0100
Received: from lists.sourceforge.net ([66.35.250.206] helo=sc8-sf-list1.sourceforge.net)
by vogon.ccgis.de with esmtp (Exim 3.36 #1 (Debian))
id 1AlAGQ-0005fb-00; Mon, 26 Jan 2004 18:11:06 +0100
Received: from localhost ([127.0.0.1] helo=projects.sourceforge.net)
by sc8-sf-list1.sourceforge.net with esmtp (Exim 4.30)
id 1Al9ps-0002Ah-Fb; Mon, 26 Jan 2004 08:43:40 -0800
Received: from sc8-sf-mx2-b.sourceforge.net ([10.3.1.12] helo=sc8-sf-mx2.sourceforge.net)
id 1Al9lm-0000vL-CD
for mapbender-users at lists.sourceforge.net; Mon, 26 Jan 2004 08:39:26 -0800
Received: from vogon.ccgis.de ([212.79.172.106])
by sc8-sf-mx2.sourceforge.net with esmtp (Exim 4.30)
id 1Al9lm-0002Np-0u
id 1AlACA-0005c1-00
for <mapbender-users at lists.sourceforge.net>; Mon, 26 Jan 2004 18:06:42 +0100
Received: from center.sz ([192.168.1.20] helo=center.shared)
id 1AlAC2-0005bk-00; Mon, 26 Jan 2004 18:06:34 +0100
Received: from [192.168.4.199] (helo=terrestris.de)
id 1Al9eg-00037K-00; Mon, 26 Jan 2004 17:32:06 +0100
Message-ID: <40154459.7020206 at terrestris.de>
Organization: terrestris
User-Agent: Mozilla/5.0 (Windows; U; Windows NT 5.0; de-DE; rv:1.0.1) Gecko/20020823 Netscape/7.0
X-Accept-Language: de-de, de
MIME-Version: 1.0
To: Gunter.Rieth at stadt.mainz.de
CC: mapbender list <mapbender-users at lists.sourceforge.net>
Subject: Re: [Mapbender-users] How to: Using the Info-Tool
References: <OF3987EF73.737F80C6-ONC1256E27.00303234-C1256E27.003C80C8 at ln.mainz.de>
X-Spam-Score: 0.0 (/)
Sender: mapbender-users-admin at lists.sourceforge.net
Errors-To: mapbender-users-admin at lists.sourceforge.net
X-BeenThere: mapbender-users at lists.sourceforge.net
X-Mailman-Version: 2.0.9-sf.net
Precedence: bulk
List-Unsubscribe: <https://lists.sourceforge.net/lists/listinfo/mapbender-users>,
<mailto:mapbender-users-request at lists.sourceforge.net?subject=unsubscribe>
List-Id: WMS Web GIS frontend Know-How exchange <mapbender-users.lists.sourceforge.net>
List-Post: <mailto:mapbender-users at lists.sourceforge.net>
List-Help: <mailto:mapbender-users-request at lists.sourceforge.net?subject=help>
List-Subscribe: <https://lists.sourceforge.net/lists/listinfo/mapbender-users>,
<mailto:mapbender-users-request at lists.sourceforge.net?subject=subscribe>
List-Archive: <http://sourceforge.net/mailarchive/forum.php?forum=mapbender-users>
Date: Mon, 26 Jan 2004 17:46:17 +0100
X-Spam-Status: No, hits=-5.0 required=7.5
tests=BAYES_10,KNOWN_MAILING_LIST,REFERENCES,
USER_AGENT_MOZILLA_UA
version=2.55
X-Spam-Level:
X-Spam-Checker-Version: SpamAssassin 2.55 (1.174.2.19-2003-05-19-exp)
Gunter,
du brauchst einen Mapserv v4.01 oder vor 3.6 -- alle Versionen zwischen
3.6x und 4.0 haben einen Bug beim "GetFeatureInfo" Request, der diesen
Fehler provoziert.
Wir haben eine 4.01er, die diesen Bug nicht mehr hat. Ich kann Sie dir
mailen, allerdings weiß ich nicht, welche Anhäne bei euch durchkommen,
sag einfach Bescheid, zur Notr stell ich Sie dir zum Download irgendwohin,
Till Adams
NEU +++ NEU +++ NEU +++ NEU
AveiN! ist Open Source
Lizensiert unter der GNU GPL
Dipl. Geogr. Till Adams
terrestris, Paulsen&Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * www.terrestris.de
The SF.Net email is sponsored by EclipseCon 2004
Premiere Conference on Open Tools Development and Integration
See the breadth of Eclipse activity. February 3-5 in Anaheim, CA.
http://www.eclipsecon.org/osdn
Mapbender-users mailing list
Mapbender-users at lists.sourceforge.net
--------------030803060303070306010800--
