[Mapserver-users] OGR unable to access datasource
Julien, Heryk
hjulien at nrcan.gc.ca
Thu Jan 29 10:16:09 EST 2004
Yes,
It looks like it.
But I was finally able to see my tble content via orginfo.
See:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00550.html
Héryk
-----Message d'origine-----
De : Normand Savard [mailto:nsavard at dmsolutions.ca]
Envoyé : Thursday, January 29, 2004 9:14 AM
À : Tyler Mitchell
Cc : Van Ulden, Joost; mapserver-users at lists.gis.umn.edu; Julien, Heryk
Objet : Re: [Mapserver-users] OGR unable to access datasource
It looks like the same problem as Julien Heryk had last week for MS
Access (0401/msg00533:
<http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00533.html
>[Mapserver-users]
Re: VirtualSpatialData (OGR Connectiontype)). I am able to reproduce it
with MS Access as well on Windows XP home edition.
Norm
Tyler Mitchell wrote:
>>Everytime I try to render the map I get the following error (the file is
>>definitely there):
>> msDrawMap(): Image handling error. Failed to draw layer named
>'OGRPoints'.
>> msOGRFileOpen(): OGR error. Open failed for OGR connection
>>`c:\inetpub\wwwroot\MS_DEMO\ogr.ovf'. File not found or unsupported
>format.
>Are you confident that your version of OGR is updated enough - does it
>include this virtual layer support? If so, then you should be able to use
>the stand alone ogrinfo utility to test it first.
>Tyler
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
