[Mapserver-users] OGR unable to access datasource
Normand Savard
nsavard at dmsolutions.ca
Thu Jan 29 13:24:25 EST 2004
Julien,
"ogrinfo" command works for me too.
Norm
Julien, Heryk wrote:
>Yes,
>It looks like it.
>But I was finally able to see my tble content via orginfo.
>See:
>http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00550.html
>Héryk
>-----Message d'origine-----
>De : Normand Savard [mailto:nsavard at dmsolutions.ca]
>Envoyé : Thursday, January 29, 2004 9:14 AM
>À : Tyler Mitchell
>Cc : Van Ulden, Joost; mapserver-users at lists.gis.umn.edu; Julien, Heryk
>Objet : Re: [Mapserver-users] OGR unable to access datasource
>It looks like the same problem as Julien Heryk had last week for MS
>Access (0401/msg00533:
><http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00533.html
>>[Mapserver-users]
>Re: VirtualSpatialData (OGR Connectiontype)). I am able to reproduce it
>with MS Access as well on Windows XP home edition.
>Norm
>Tyler Mitchell wrote:
>>>Everytime I try to render the map I get the following error (the file is
>>>definitely there):
>>> msDrawMap(): Image handling error. Failed to draw layer named
>>'OGRPoints'.
>>> msOGRFileOpen(): OGR error. Open failed for OGR connection
>>>`c:\inetpub\wwwroot\MS_DEMO\ogr.ovf'. File not found or unsupported
>>format.
>>Are you confident that your version of OGR is updated enough - does it
>>include this virtual layer support? If so, then you should be able to use
>>the stand alone ogrinfo utility to test it first.
>>Tyler
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
