[Mapserver-users] OGR unable to access datasource
Van Ulden, Joost
jvanulde at nrcan.gc.ca
Thu Jan 29 15:52:28 EST 2004
Hi Tyler,
Here is the output from ogrinfo. Looks like its working, however I still
unable to get mapserver to connect. I have tried putting the
<OGRVRTDataSource> directly in the mapfile CONNECTION and still get the same
error:
msDrawMap(): Image handling error. Failed to draw layer named 'OGRPoints'.
msOGRFileOpen(): OGR error. Open failed for OGR connection `
ODBC:foo/foo at mydsn,Desc_story Desc_story wkbPoint WGS84 '. File not found or
unsupported format.
Looking forward to your response.
C:\OpenEV_FW\bin>ogrinfo C:\inetpub\wwwroot\MS_DEMO\mapserver\data\ogr.ovf
ERROR 4: Update access not supported for VRT datasources.
Had to open data source read-only.
INFO: Open of `C:\inetpub\wwwroot\MS_DEMO\mapserver\data\ogr.ovf'
using driver `VRT' successful.
1: story (Point)
story ERROR 4: Update access not supported for VRT datasources. Had to open
OGRFeature(story):87
desc_id (String) = 400E2174-65BF-3224-7CEF493349368AE7
group_id (String) = 0
comm_id (String) = DE9E2A07-B0D0-EA24-1BD6282422D24117
user_id (String) = 4A335096-7ADD-419B-9E16-1995F233D3F8
elev (Real) = 0
units (String) =
rtype (String) =
mu (String) =
ldesc (String) =
min (String) =
lmu (String) =
struct (String) =
txt (String) =
snum (String) =
purp (String) =
sfeat (String) =
azi (Real) = 0
dip (Real) = 0
stdesc (String) =
name (String) =
sdesc (String) =
story_x (Real) = -1993136.4272429
story_y (Real) = 471899.80462409
share (Integer) = 0
release (Integer) = 1
date (String) = 2004-01-22 16:08:11.000
POINT (-1993136.427 471899.805 0.000)
Joost van Ulden
Programmer/Analyst
Natural Resources Canada / Ressources naturelles Canada
Geological Survey of Canada / Commission geologique du Canada
101 - 605 Robson Street / 101 - 605 rue Robson
Vancouver, B.C. / Vancouver (C.-B.)
V6B 5J3
Office/Bureau: 604.666.7525
fax/telecopieur: 604.666.1124
> -----Original Message-----
> From: Tyler Mitchell [mailto:TMitchell at lignum.com]
> Sent: Thursday, January 29, 2004 9:46 AM
> To: Van Ulden, Joost
> Subject: Re: [Mapserver-users] OGR unable to access datasource
> > LAYER
> > NAME OGRPoints
> > TYPE POINT
> > CONNECTIONTYPE OGR
> > CONNECTION "c:\inetpub\wwwroot\MS_DEMO\ogr.ovf"
> > DATA "Desc_story"
> > STATUS default
> > CLASS
> > COLOR 255 0 0
> > END
> I just asked for your layer definition, I see it here in your
> old email, so nevermind. Are you sure about the text case for
> the "DATA" parameter? Send me your output from ogrinfo!
