[Mapserver-users] Projection Systems question
Amit S BEHERE
abehere at cs.ucsd.edu
Thu Jan 29 13:43:39 EST 2004
I found a very interesting thing. I did change the contrast so that I can
debug. I can see one teensy tiny tree that moves around if I change the
extent slightly. However I see only that one tree when I should see a
bunch of trees. Also The tree is a very tiny dot on screen. Even if I
change the MINSIZE on the class for the layer it doesnt help the map file
is attached below. Could it be a problem in the shape file (it opens up
fine in ArcView though, thats how I got the extent)
MAP
IMAGETYPE PNG
EXTENT 383778 3760227 389212 3763677
SIZE 400 300
SHAPEPATH "data"
IMAGECOLOR 0 0 0
PROJECTION
# "proj=laea"
# "ellps=clrk66"
# "lat_0=45"
#"lon_0=-100"
# Alternatively, you can specify an EPSG code.
"init=epsg:26911"
END
# Start of LAYER DEFINITIONS
LAYER # States polygon layer begins here
NAME vernon_trees
DATA vernon_trees
STATUS DEFAULT
TYPE POINT
PROJECTION
"init=epsg:26911"
END
CLASS
COLOR 255 255 255
MINSIZE 300
END
END # States polygon layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
Amit Behere.
UCSD.
"Technology doesn't make your life more difficult or easy, it just changes
the rules"......Vishwanathan Anand
On Wed, 28 Jan 2004, Ed McNierney wrote:
> Amit -
> Thanks! First, I notice that you're drawing 10% gray points on a white
> background, which is going to make them pretty hard to see. You might
> try setting the COLOR in the data layer to 0 128 0 or something
> distinctive while you're debugging.
> If you are getting a valid PNG image (no broken link icon) that just is
> all white, then I would double-check the extents you've chosen to see if
> you've gotten them correct. Since your layer is called vernon_trees,
> and your extents are around Vernon, CA, though, I'm guessing they are
> OK.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com
> -----Original Message-----
> From: Amit S BEHERE [mailto:abehere at cs.ucsd.edu]
> Sent: Wednesday, January 28, 2004 11:25 PM
> To: Ed McNierney
> Cc: Amit S BEHERE; mapserver-users at lists.gis.umn.edu;
> amitbehere at rediffmail.com
> Subject: RE: [Mapserver-users] Projection Systems question
> Hi
> I am sorry for not mentioning the problem correctly. Well, I am getting
> a PNG back but it is blank. I have a test.map file and I use the
> following url http://pune.com/mapserver/mapserv.exe?map=location of my
> .map
> file+mode=map. i.e I am using the same parameters as are being used in
> examples.
> Amit Behere.
> UCSD.
> changes the rules"......Vishwanathan Anand
> > Amit -
> > You didn't say what the problem is. What is happening (or not
> > happening) when you try to generate a map from this mapfile? What is
> > the URL you're using (i.e. what CGI parameters are you specifying)?
> > - Ed
> > Ed McNierney
> > TopoZone.com
> > Sent: Wednesday, January 28, 2004 10:42 PM
> > To: mapserver-users at lists.gis.umn.edu
> > Cc: amitbehere at rediffmail.com
> > Subject: [Mapserver-users] Projection Systems question
> > Hi all,
> > I am having the following problem. I have a shapefile with the data in
> > projection system 1983_UTM_Zone_11N. I am trying to set up a layer in
> > mapserver using this shape file. I took the example1.map file in the
> > tutorial and made changes to it. The salient ones being
> > changing the extent to the correct coordinates (found via ArcView)
> > changing the projection to init epsg: 26911 (for UTM Zone 11 N) and
> > changing the name and data setting for layer.
> > I also changed the type to point and set minsize to be 20.
> > I am also appending the mapfile. Can some one tell me what I am doing
> > wrong ? Thanks in advance
> > MAP
> > IMAGETYPE PNG
> > EXTENT 385538 3761010 391329 3764477
> > SIZE 400 300
> > SHAPEPATH "data"
> > IMAGECOLOR 255 255 255
> > PROJECTION
> > # "proj=laea"
> > # "ellps=clrk66"
> > # "lat_0=45"
> > #"lon_0=-100"
> > "init=epsg:26911"
> > END
> > NAME vernon_trees
> > DATA vernon_trees
> > STATUS DEFAULT
> > TYPE POINT
> > PROJECTION
> > "init=epsg:26911"
> > END
> > CLASS
> > COLOR 232 232 232
> > MINSIZE 20
> > END
> > Amit Behere.
> > UCSD.
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
