[Mapserver-users] Projection Systems question
Ed McNierney
ed at topozone.com
Wed Jan 28 23:36:08 EST 2004
Amit -
Thanks! First, I notice that you're drawing 10% gray points on a white
background, which is going to make them pretty hard to see. You might
try setting the COLOR in the data layer to 0 128 0 or something
distinctive while you're debugging.
If you are getting a valid PNG image (no broken link icon) that just is
all white, then I would double-check the extents you've chosen to see if
you've gotten them correct. Since your layer is called vernon_trees,
and your extents are around Vernon, CA, though, I'm guessing they are
OK.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com
-----Original Message-----
From: Amit S BEHERE [mailto:abehere at cs.ucsd.edu]
Sent: Wednesday, January 28, 2004 11:25 PM
To: Ed McNierney
Cc: Amit S BEHERE; mapserver-users at lists.gis.umn.edu;
amitbehere at rediffmail.com
Subject: RE: [Mapserver-users] Projection Systems question
Hi
I am sorry for not mentioning the problem correctly. Well, I am getting
a PNG back but it is blank. I have a test.map file and I use the
following url http://pune.com/mapserver/mapserv.exe?map=location of my
.map
file+mode=map. i.e I am using the same parameters as are being used in
examples.
Amit Behere.
UCSD.
"Technology doesn't make your life more difficult or easy, it just
changes the rules"......Vishwanathan Anand
On Wed, 28 Jan 2004, Ed McNierney wrote:
> Amit -
> You didn't say what the problem is. What is happening (or not
> happening) when you try to generate a map from this mapfile? What is
> the URL you're using (i.e. what CGI parameters are you specifying)?
> - Ed
> Ed McNierney
> TopoZone.com
> Sent: Wednesday, January 28, 2004 10:42 PM
> To: mapserver-users at lists.gis.umn.edu
> Cc: amitbehere at rediffmail.com
> Subject: [Mapserver-users] Projection Systems question
> Hi all,
> I am having the following problem. I have a shapefile with the data in
> projection system 1983_UTM_Zone_11N. I am trying to set up a layer in
> mapserver using this shape file. I took the example1.map file in the
> tutorial and made changes to it. The salient ones being
> changing the extent to the correct coordinates (found via ArcView)
> changing the projection to init epsg: 26911 (for UTM Zone 11 N) and
> changing the name and data setting for layer.
> I also changed the type to point and set minsize to be 20.
> I am also appending the mapfile. Can some one tell me what I am doing
> wrong ? Thanks in advance
> MAP
> IMAGETYPE PNG
> EXTENT 385538 3761010 391329 3764477
> SIZE 400 300
> SHAPEPATH "data"
> IMAGECOLOR 255 255 255
> PROJECTION
> # "proj=laea"
> # "ellps=clrk66"
> # "lat_0=45"
> #"lon_0=-100"
> # Alternatively, you can specify an EPSG code.
> "init=epsg:26911"
> END
> # Start of LAYER DEFINITIONS
> LAYER # States polygon layer begins here
> NAME vernon_trees
> DATA vernon_trees
> STATUS DEFAULT
> TYPE POINT
> PROJECTION
> "init=epsg:26911"
> END
> CLASS
> COLOR 232 232 232
> MINSIZE 20
> END
> END # States polygon layer ends here
> # End of LAYER DEFINITIONS -------------------------------
> END # end of map file/object
> Amit Behere.
> UCSD.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
