[Mapserver-users] Q: Dynamic Legends
Jean-Henry Berevoescu
bjh at globexplorer.com
Thu Jan 29 15:51:08 EST 2004
No. I have, for example, one of the layers with a number of classes
(say, streets, with
each type of street having its own class). In a certain area, at a
certain scale, one could
get, for example, only highways. What I want is to have the legend
showing only the
symbols/definitions for what is actually in the map at a certain moment.
Jean
Martin, Daniel A wrote:
>Do you mean layers that are on, and within range, but are not visible
>because of your current location? I don't believe that is possible.
>However, the default is to hide layers that are not visible or have a
>status of OFF. However, if you have layers that have a status of
>DEFAULT, then those are going to show no matter what.
>Am I misunderstanding you?
>-Dan
>>-----Original Message-----
>>From: mapserver-users-admin at lists.gis.umn.edu
>>[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
>>Sent: Thursday, January 29, 2004 1:16 PM
>>To: mdoggett at coas.oregonstate.edu
>>Cc: mapserver-users at lists.gis.umn.edu
>>Subject: Re: [Mapserver-users] Q: Dynamic Legends
>>I tried that one and all the possible combinations (and their
>>sum). Nothing works.
>>Thanks,
>>Jean
>>Matt Doggett wrote:
>>>I believe HTML legends will do the trick. In the
>>legend_template.html
>>>file you could specify [leg_class_html opt_flag=12] for example. see
>>>the HTML legend How-To for more details about the opt_flag bit mask.
>>>http://mapserver.gis.umn.edu/doc40/html-legend-howto.html
>>>MD
>>>admin at lists.gis.umn.edu] On Behalf Of Jean-Henry Berevoescu
>>>Sent: Wednesday, January 28, 2004 8:12 PM
>>>To: mapserver-users at lists.gis.umn.edu
>>>Subject: [Mapserver-users] Q: Dynamic Legends
>>>Hi,
>>>Is there a way to have the legend dynamically show only the classes of
>>a
>>>layer actually
>>>shown in a map (not the whole defined set in the mapfile)?
>>>Jean
>>>_______________________________________________
>>>Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
