[Mapserver-users] Q: Dynamic Legends
Martin, Daniel A
Daniel.A.Martin at erac.com
Thu Jan 29 16:51:28 EST 2004
I'm pretty sure MapServer does not support that. Currently legends only
check "Is this class/layer within range?".
I think (though I am not a dev) that the legend gets created without
even knowing the output on the map. It simply checks the map file, and
knows immediately what layers are in range using the minscale/maxscale
settings, and knows what the status of the layers are. You can request
a legend from mapserver without ever requesting a map.
-Dan
> -----Original Message-----
> From: Jean-Henry Berevoescu [mailto:bjh at globexplorer.com]
> Sent: Thursday, January 29, 2004 3:34 PM
> To: Martin, Daniel A
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Q: Dynamic Legends
> Yes and no. Actually in your scenario I still will have some unsolved
> issues.
> For example: let's say that at a certain scale, all the
> layers are to be
> shown
> so I can have Drives, Places, Streets, Roads, Highways and so
> on - but on the actual map in the actual area it happens to
> be a wasteland with only a Road in it. In this case what one
> would expect from a classical map would be to only see that
> symbol - the symbol of the Road type of streets. See
> what I mean?
> Maybe the Streets example is not the best for the problem we
> have here. Say, a vegetation zones map. One can have, say, 25
> types of vegetation.
> At a certain
> point and at a certain scale, on the map will only be 3
> types. No matter how one will play with layering, this is not
> exactly a scale-related
> problem, but
> data-related problem. "Does the map shows now forest and
> grassland now? Then the legend should not present all the
> possible vegetation types".
> Thanks for your answer,
> Jean
> Martin, Daniel A wrote:
> >I do exactly the same thing. The way I do it, I have two layers
> >pointing at the same data. One has only the highway class, and the
> >other has all street types. But, here's the trick. Name
> both layers
> >the SAME exact name. Now, have the range set where the
> minscale of the
> >highway layer is the maxscale of the detailed street layer.
> >As the user zooms in and out, MapServer will naturally
> transition from
> >highways to detailed streets. However, the legend will show exactly
> >what you are asking for. And, by naming both layers the
> same name, the
> >status (on/off) will carry over as the user zooms. If the highway
> >layer was on, the street layer will also be on when the user
> zooms in.
> >I know it may sound strange, but I promise it works beautifully.
> >-Dan
> >>Sent: Thursday, January 29, 2004 2:51 PM
> >>No. I have, for example, one of the layers with a number of classes
> >>(say, streets, with
> >>each type of street having its own class). In a certain area, at a
> >>certain scale, one could
> >>get, for example, only highways. What I want is to have the legend
> >>showing only the
> >>symbols/definitions for what is actually in the map at a
> >>certain moment.
> >>Jean
> >>>Do you mean layers that are on, and within range, but are
> >>not visible
> >>>because of your current location? I don't believe that is
> possible.
> >>>However, the default is to hide layers that are not visible
> >>or have a
> >>>status of OFF. However, if you have layers that have a status of
> >>>DEFAULT, then those are going to show no matter what.
> >>>Am I misunderstanding you?
> >>>-Dan
> >>>>From: mapserver-users-admin at lists.gis.umn.edu
> >>>>[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> >>>>Sent: Thursday, January 29, 2004 1:16 PM
> >>>>To: mdoggett at coas.oregonstate.edu
> >>>>I tried that one and all the possible combinations (and
> their sum).
> >>>>Nothing works.
> >>>>Thanks,
> >>>>Jean
> >>>>Matt Doggett wrote:
> >>>>>I believe HTML legends will do the trick. In the
> >>>>legend_template.html
> >>>>>file you could specify [leg_class_html opt_flag=12] for
> >>example. see
> >>>>>the HTML legend How-To for more details about the opt_flag
> >>bit mask.
> >>>>>http://mapserver.gis.umn.edu/doc40/html-legend-howto.html
> >>>>>MD
> >>>>>admin at lists.gis.umn.edu] On Behalf Of Jean-Henry Berevoescu
> >>>>>Sent: Wednesday, January 28, 2004 8:12 PM
> >>>>>To: mapserver-users at lists.gis.umn.edu
> >>>>>Subject: [Mapserver-users] Q: Dynamic Legends
> >>>>>Hi,
> >>>>>Is there a way to have the legend dynamically show only
> >>the classes
> >>>>>of
> >>>>a
> >>>>>layer actually
> >>>>>shown in a map (not the whole defined set in the mapfile)?
> >>>>>Jean
> >>>>>_______________________________________________
> >>>>>Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> >>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
