[Mapserver-users] Q: Dynamic Legends
Jean-Henry Berevoescu
bjh at globexplorer.com
Thu Jan 29 16:33:50 EST 2004
Yes and no. Actually in your scenario I still will have some unsolved
issues.
For example: let's say that at a certain scale, all the layers are to be
shown
so I can have Drives, Places, Streets, Roads, Highways and so on - but on
the actual map in the actual area it happens to be a wasteland with only a
Road in it. In this case what one would expect from a classical map would be
to only see that symbol - the symbol of the Road type of streets. See
what I mean?
Maybe the Streets example is not the best for the problem we have here.
Say, a vegetation zones map. One can have, say, 25 types of vegetation.
At a certain
point and at a certain scale, on the map will only be 3 types. No matter how
one will play with layering, this is not exactly a scale-related
problem, but
data-related problem. "Does the map shows now forest and grassland now? Then
the legend should not present all the possible vegetation types".
Thanks for your answer,
Jean
Martin, Daniel A wrote:
>I do exactly the same thing. The way I do it, I have two layers
>pointing at the same data. One has only the highway class, and the
>other has all street types. But, here's the trick. Name both layers
>the SAME exact name. Now, have the range set where the minscale of the
>highway layer is the maxscale of the detailed street layer.
>As the user zooms in and out, MapServer will naturally transition from
>highways to detailed streets. However, the legend will show exactly
>what you are asking for. And, by naming both layers the same name, the
>status (on/off) will carry over as the user zooms. If the highway layer
>was on, the street layer will also be on when the user zooms in.
>I know it may sound strange, but I promise it works beautifully.
>-Dan
>>-----Original Message-----
>>From: Jean-Henry Berevoescu [mailto:bjh at globexplorer.com]
>>Sent: Thursday, January 29, 2004 2:51 PM
>>To: Martin, Daniel A
>>Cc: mapserver-users at lists.gis.umn.edu
>>Subject: Re: [Mapserver-users] Q: Dynamic Legends
>>No. I have, for example, one of the layers with a number of classes
>>(say, streets, with
>>each type of street having its own class). In a certain area, at a
>>certain scale, one could
>>get, for example, only highways. What I want is to have the legend
>>showing only the
>>symbols/definitions for what is actually in the map at a
>>certain moment.
>>Jean
>>>Do you mean layers that are on, and within range, but are
>>not visible
>>>because of your current location? I don't believe that is possible.
>>>However, the default is to hide layers that are not visible
>>or have a
>>>status of OFF. However, if you have layers that have a status of
>>>DEFAULT, then those are going to show no matter what.
>>>Am I misunderstanding you?
>>>-Dan
>>>>From: mapserver-users-admin at lists.gis.umn.edu
>>>>[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
>>>>Sent: Thursday, January 29, 2004 1:16 PM
>>>>To: mdoggett at coas.oregonstate.edu
>>>>I tried that one and all the possible combinations (and their
>>>>sum). Nothing works.
>>>>Thanks,
>>>>Jean
>>>>Matt Doggett wrote:
>>>>>I believe HTML legends will do the trick. In the
>>>>legend_template.html
>>>>>file you could specify [leg_class_html opt_flag=12] for
>>example. see
>>>>>the HTML legend How-To for more details about the opt_flag
>>bit mask.
>>>>>http://mapserver.gis.umn.edu/doc40/html-legend-howto.html
>>>>>MD
>>>>>admin at lists.gis.umn.edu] On Behalf Of Jean-Henry Berevoescu
>>>>>Sent: Wednesday, January 28, 2004 8:12 PM
>>>>>To: mapserver-users at lists.gis.umn.edu
>>>>>Subject: [Mapserver-users] Q: Dynamic Legends
>>>>>Hi,
>>>>>Is there a way to have the legend dynamically show only
>>the classes
>>>>>of
>>>>a
>>>>>layer actually
>>>>>shown in a map (not the whole defined set in the mapfile)?
>>>>>Jean
>>>>>_______________________________________________
>>>>>Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
>>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
