[Mapserver-users] Changing map file parameters via URL
Gleiner Crivelini
gleinerteruel at hotmail.com
Fri Jan 30 06:47:27 EST 2004
<html><div style='background-color:'><DIV class=RTE>Hi everyone.</DIV>
<DIV class=RTE>I get problems when trying to change map file parameters via URL, that is CGI procedurement.</DIV>
<DIV class=RTE>Does anybody know what exactly is the syntax to change the DATA parameter via URL?</DIV>
<DIV class=RTE>When I tryied the answer was:</DIV>
<DIV class=RTE><EM>Error with POSTGIS data variable. You specified '&lt;check your .map file&gt;'.<br><BR>Standard ways of specifiying are : <br><BR>(1) 'geometry_column from geometry_table' <br><BR>(2) 'geometry_column from (&lt;sub query&gt;) as foo using unique &lt;column name&gt; using SRID=&lt;srid#&gt;' <br><br></EM></DIV>
<DIV class=RTE><EM>Make sure you put in the 'using unique &lt;column name&gt;' and 'using SRID=#' clauses in.<BR></EM>What should be understood by (&lt;sub query&gt;) and column name&gt ?</DIV>
<DIV class=RTE>Gleiner.</DIV></div><br clear=all><hr>MSN Messenger: converse com os seus amigos online. <a href="http://g.msn.com/8HMABRBR/2755??PS=">Instale grátis. Clique aqui. </a> </html>
