[Mapserver-users] I have some landsat 7 data that I want to t
ile : overlap + transparency
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Fri Jan 30 17:59:39 EST 2004
Hi Stephen,
What are your requirements for using the Landsat 7 Orthoimagery in
MapServer?
The CCRS WMS has the entire Landsat 7 Orthorectified Imagery collection,
which is on GeoGratis, available as OGC:WMS:
URL: http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi
Layer name: L7O_B743:CEOWARE2
Note that this layer is also timestamped, i.e. you can query via TIME in
OGC:WMS also. The scenes' black areas are transparent.
Just thought it'd be easier to point to an OGC:WMS of this data rather than
roll your own.
Another comment: I'd be interested, as a separate exercise, how MapServer
deals with overlapping images in a given layer. What kind of algorithm is
done between scenes which overlap?
Thanks
..Tom
Tom Kralidis
Systems Scientist
Environment Canada
Tel: +01-905-336-4409
http://www.ec.gc.ca/cise/
> -----Original Message-----
> From: Stephen Clark [mailto:stephen.clark at focus.ca]
> Sent: Friday, January 30, 2004 6:52 PM
> To: Frank Warmerdam
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] I have some landsat 7 data
> that I want to tile : overlap + transparency
> Frank,
> My landsat data is from the Geogratis web site :
> http://geogratis.cgdi.gc.ca/download/landsat_7/ortho/geotiff/utm/
> Specifically these three scenes as example:
> tm/047021/
> tm/048021/
> tm/049021/
> I compressed the files to ECW and produced this layer:
> LAYER
> NAME landsat_048_021_rgb
> DATA
> "d:/datasets/imagery/landsat/ecw/048021_0100_990804_l7_743_utm10.ecw"
> TYPE RASTER
> STATUS ON
> TRANSPARENCY 60
> # turn off the black background in the image files
> OFFSITE 0 0 0
> END
> >Do all the images have the same background value? YES -- they do.
> There is a residual amount of black fuzziness around the
> scenes after using the above OFFSITE command.
> Here is a LAYER file for the tiled index of Landsat scenes:
> LAYER
> NAME landsat_tile
> TILEINDEX "d:/datasets/imagery/landsat/landsat_index.shp"
> TILEITEM "location"
> TYPE RASTER
> STATUS ON
> TRANSPARENCY 60
> OFFSITE 0 0 0
> METADATA
> WMS_TITLE "Lansdat 7 Imagery "
> WMS_ABSTRACT "N/A"
> WMS_SRS "EPSG:26910"
> END
> END
> But this tiled layer does not have any transparency. How
> would I fix this?
> thanks
> Stephen
> ----- Original Message -----
> From: "Frank Warmerdam" <warmerdam at pobox.com>
> To: "Stephen Clark" <stephen.clark at focus.ca>
> Cc: <mapserver-users at lists.gis.umn.edu>
> Sent: Friday, January 30, 2004 2:31 PM
> > Stephen Clark wrote:
> > > Hi All,
> > > I have some landsat 7 data that I want to tile but the scenes
> > > overlap.
> > > Can I use some sort of command that can be added to the
> "gdaltindex"
> > > command to add a transparency value to these scenes so that the
> > > overlap areas can show through.
> > Stephen,
> > Do all the images have the same background value? If so, use it as
> > the offsite value for the whole layer and it will be used
> with all the
> > images. The other alternative is to store the tiles in a format for
> > which GDAL recognises "nodata" values, but this isn't very
> convenient
> > to arrange. There is no way to include nodata values in the raster
> > tile index.
> > Best regards,
> > I set the clouds in motion - turn up | Frank Warmerdam,
> > light and sound - activate the windows | http://pobox.com/~warmerdam
> > and watch the world go round - Rush | Geospatial
> Programmer for Rent
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
