[Mapserver-users] Projection Systems question
David Fawcett
David.Fawcett at state.mn.us
Fri Jan 30 18:04:49 EST 2004
This is a MIME message. If you are reading this text, you may want to
consider changing to a mail reader or gateway that understands how to
properly handle MIME multipart messages.
--=__PartD0F18701.1__=
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Content-Disposition: inline
Amit, List:
I played with the data and the mapfile. I was able to reproduce what
Amit was seeing, and display all of the points in the .shp. I figured
out how to control the issue, but I am not sure of the root cause.
I modified the MAP file to improve symbology and add a label. When I
called the map using URL
'http://127.0.0.1/cgi-bin/ms4/mapserv.exe?map=c%3A%5Capache%5Chtdocs%5Camittest%5Ctest.map&mode=map'
one point displays, with a label, it is identified as TREEID 431 which
is locate in the south west region of the extent. This isn't what I
expected to see, but it reproduces what Amit was seeing. The point
wasn't noise, but an actual point from the .shp.
When I added a MINSCALE of 1000000to the WEB object, I can see all of
the points in the shp.
I therefore assume that there is some issue with the extent in the MAP
file and the MINSCALE is preventing it from zooming too far.
Ed, can you shed some light on this?
I have attached images of the two conditions that I have described.
David.
Here is the MAP file____________________________
MAP
NAME test
IMAGETYPE PNG
STATUS ON
EXTENT 385538 3761010 391329 3764477
UNITS METERS
SIZE 400 400
SHAPEPATH "c:\apache\htdocs\amittest\data"
FONTSET symbols/fonts/fonts.list
WEB
IMAGEPATH "c:\Apache\htdocs\tmp\"
IMAGEURL "/tmp/"
#MINSCALE 100000 #with this enabled, produces image with all
points
#MAXSCALE 15500000 #see 'with_scale_restrictions.png'
END
# Start of symbol definition
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
# Start of LAYER DEFINITIONS
LAYER
NAME trees
DATA vernon_trees
STATUS DEFAULT
TYPE POINT
LABELITEM "TREEID"
CLASS
COLOR 255 0 51
SYMBOL 'circle'
SIZE 6
#LABEL
#TYPE TRUETYPE
#FONT "arial-bold"
#SIZE 10
#POSITION auto
#SHADOWCOLOR 204 204 204
#ANTIALIAS TRUE
#END
END
END # layer ends here
END # end of map file/object
__________________________________________________
David J. Fawcett
MN Office of Environmental Assistance
Content-Type: image/png; name="no_scale_restrictions.png"
Content-Transfer-Encoding: base64
Content-Disposition: attachment; filename="no_scale_restrictions.png"
Content-Description: Portable Network Graphics Format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Content-Type: image/png; name="with_scale_restrictions.png"
Content-Disposition: attachment; filename="with_scale_restrictions.png"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--=__PartD0F18701.1__=--
