[Mapserver-users] Projection Systems question
Ed McNierney
ed at topozone.com
Fri Jan 30 21:52:28 EST 2004
David -
Thanks for looking into this - I'll try to reproduce the problem and
take a look.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com
-----Original Message-----
From: David Fawcett [mailto:David.Fawcett at state.mn.us]
Sent: Friday, January 30, 2004 6:05 PM
To: David.Fawcett at state.mn.us
Cc: abehere at cs.ucsd.edu; mapserver-users at lists.gis.umn.edu;
amitbehere at rediffmail.com
Subject: RE: [Mapserver-users] Projection Systems question
Amit, List:
I played with the data and the mapfile. I was able to reproduce what
Amit was seeing, and display all of the points in the .shp. I figured
out how to control the issue, but I am not sure of the root cause.
I modified the MAP file to improve symbology and add a label. When I
called the map using URL
'http://127.0.0.1/cgi-bin/ms4/mapserv.exe?map=c%3A%5Capache%5Chtdocs%5Ca
mittest%5Ctest.map&mode=map'
one point displays, with a label, it is identified as TREEID 431 which
is locate in the south west region of the extent. This isn't what I
expected to see, but it reproduces what Amit was seeing. The point
wasn't noise, but an actual point from the .shp.
When I added a MINSCALE of 1000000to the WEB object, I can see all of
the points in the shp.
I therefore assume that there is some issue with the extent in the MAP
file and the MINSCALE is preventing it from zooming too far.
Ed, can you shed some light on this?
I have attached images of the two conditions that I have described.
David.
Here is the MAP file____________________________
MAP
NAME test
IMAGETYPE PNG
STATUS ON
EXTENT 385538 3761010 391329 3764477
UNITS METERS
SIZE 400 400
SHAPEPATH "c:\apache\htdocs\amittest\data"
FONTSET symbols/fonts/fonts.list
WEB
IMAGEPATH "c:\Apache\htdocs\tmp\"
IMAGEURL "/tmp/"
#MINSCALE 100000 #with this enabled, produces image with all
points
#MAXSCALE 15500000 #see 'with_scale_restrictions.png'
END
# Start of symbol definition
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
# Start of LAYER DEFINITIONS
LAYER
NAME trees
DATA vernon_trees
STATUS DEFAULT
TYPE POINT
LABELITEM "TREEID"
CLASS
COLOR 255 0 51
SYMBOL 'circle'
SIZE 6
#LABEL
#TYPE TRUETYPE
#FONT "arial-bold"
#SIZE 10
#POSITION auto
#SHADOWCOLOR 204 204 204
#ANTIALIAS TRUE
#END
END
END # layer ends here
END # end of map file/object
__________________________________________________
David J. Fawcett
MN Office of Environmental Assistance
