[Mapserver-users] Timeout for wms layer
Pericles Nacionales
nacional at cbs.umn.edu
Thu Jul 1 13:04:23 EDT 2004
Oops! A small error on my previous post, your WMS server's IMAGEURL
should be "/ms_tmp/", with the slash at the end. It's required.
-Perry
On Thu, 1 Jul 2004, Pericles Nacionales wrote:
> Martin,
> First, remove "http://localhost" from your client's IMAGEURL value. It
> should be like this: IMAGEURL "/wms/ms_tmp/"
> Also, remove "http://http://www.moeldrup.dk" from your server's IMAGEURL
> path. It should be: IMAGEURL "/ms_tmp"
> If that still doesn't work, review
> http://mapserver.gis.umn.edu/doc42/wms-server-howto.html and
> http://mapserver.gis.umn.edu/doc42/wms-client-howto.html.
> Good luck!
> -Perry
> Pericles S. Nacionales
> nacional at biosci.umn.edu
> On Thu, 1 Jul 2004, [ISO-8859-1] Martin Høgh wrote:
> > Dear List
> > I've posted this message
> > http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0406/msg00759.html
> > earlier without much luck., so I'll try again.
> > I'm trying to use Mapserver as a wms client for this server
> > http://www.moeldrup.dk/scripts/mapserv.exe?map=d:/www/website/Ortofoto/moeldrup.map
> > I am administrating this server so I can alter the settings if necessary.
> > The problem is that when the layer from this server is requested by a
> > Mapserver client it will timeout. A .img.tmp of 0k file is created and
> > no errors from the client.
> > I've tested with ms3.6.6 (both php/mapscript and cgi) on linux and ms4.0
> > on winxp with same result
> > The projection for all is set to "epsg:32632". But actually the data
> > projected in a odd Danish system which can not be reprojected. But I
> > believe that an epsg or auto code must be specified.
> > My map-file (client)
> > # Start of map file
> > NAME Province
> > STATUS ON
> > SIZE 700 440
> > EXTENT -277553.292530 232924.427400 -252200.662530 251396.532600
> > UNITS METERS
> > #SHAPEPATH "../data/grundkort"
> > IMAGECOLOR 215 226 233
> > FONTSET "../etc/fonts.txt"
> > IMAGETYPE png
> > PROJECTION
> > "init=epsg:32632"
> > END
> > WEB
> > # On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
> > # of the drive where the .MAP file resides.
> > IMAGEPATH "C:\Programmer\EasyPHP1-7\www\wms\ms_tmp\"
> > IMAGEURL "http://localhost/wms/ms_tmp/"
> > LOG "C:\Programmer\EasyPHP1-7\www\wms\map.log"
> > END
> > LAYER
> > NAME orto
> > METADATA
> > "wms_srs" "EPSG:32632"
> > "wms_connectiontimeout" "15"
> > END
> > TYPE RASTER
> > STATUS default
> > CONNECTIONTYPE WMS
> > CONNECTION
> > "http://www.moeldrup.dk/scripts/mapserv.exe?map=d:/www/website/Ortofoto/moeldrup.map&WMTVER=1.0.0&FORMAT=image/jpeg&"
> > END
> > end #mapfile
> > mapfile (server)
> > # Start of map file
> > NAME Moeldrup_WMS
> > STATUS ON
> > UNITS METERS
> > IMAGECOLOR 255 255 255
> > IMAGETYPE png
> > PROJECTION
> > "init=epsg:32632"
> > END
> > SIZE 700 440
> > # Start of web interface definition
> > web
> > IMAGEPATH "D:\www\website\ms_tmp\"
> > IMAGEURL "http://http://www.moeldrup.dk/ms_tmp/"
> > LOG "map.log"
> > METADATA
> > "wms_title" "Møldrup ortofoto WMS server"
> > "wms_onlineresource"
> > "http://www.moeldrup.dk/scripts/mapserv.exe?map=d:/www/website/Ortofoto/moeldrup.map&WMTVER=1.0.0&"
> > END
> > END
> > # Start of layer definitions
> > LAYER
> > NAME "Ortofoto"
> > STATUS default
> > TILEINDEX "KX-1569_Index.shp"
> > TILEITEM "location"
> > TYPE RASTER
> > PROJECTION
> > "init=epsg:32632"
> > END
> > END
> > END # Map File
> > Best regards
> > Martin
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
