[Mapserver-users] creating a new layer with PHP/Mapscript
eric.belenfant
eric.belenfant at ac-orleans-tours.fr
Thu Jul 1 05:55:41 EDT 2004
i'm using php mapscript 4.0 and .tab files from MAPINFO.
I try to generate some layers on the fly with php.
Here is the piece of code
$couche_modele = $map->getLayerByName("couche_modele");
$modele_classe = $couche_modele->getClass(0);
// Affichage/Masquage des couches
$layer = *ms_newLayerObj*($map,$couche_modele);
$layer->set("name","total_sts");
$layer->set("classitem","total_sts");
$class = ms_newClassObj($layer);
$class->setexpression("[total_sts]>0");
$style = ms_newStyleObj($class);
$style->color->setRGB(255,255,200);
$colorSTS = rgb2html(Array( $style->color->red,
$style->color->green,
$style->color->blue));
if (isset($HTTP_POST_VARS["total_sts"])){
print_r($map->getLayersdrawingorder());
$layer->set("status",MS_ON);
$checkSTS="CHECKED";
}else
$layer->set("status",MS_OFF);
The new layer i create is not visible, however all the propoerties of
the layer are OK when i echo them .
What is wrong in my code ?
Am i missing something ?
eric
