[Mapserver-users] WMS Raster problem
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Tue Jul 6 20:09:09 EDT 2004
Worked -- I compiled --without-tiff, works fine.
BTW, performance is GREAT on a 600MB TIFF file -- kudos developers!!!!
Thanks for everyone's help.
..Tom
> -----Original Message-----
> From: Paul Ramsey [mailto:pramsey at refractions.net]
> Sent: Tuesday, July 06, 2004 6:21 PM
> To: Kralidis,Tom [Burlington]
> Subject: Re: [Mapserver-users] WMS Raster problem
> Tom,
> You definitely want to recompile... --without-tiff is your friend.
> Steve Lime is right, the internal TIFF handling should really
> be ripped
> out, it is quite flakey.
> Paul
> On Tuesday, July 6, 2004, at 01:12 PM, Kralidis,Tom
> >> From: Pagurek, Debbie [mailto:PAGUREKD at AGR.GC.CA]
> >> Sent: Tuesday, July 06, 2004 4:08 PM
> >> To: Kralidis,Tom [Burlington]; mapserver-users at lists.gis.umn.edu
> >> Subject: RE: [Mapserver-users] WMS Raster problem
> >> Tom,
> >> I can use WMS to show a tif - here are the relevant parts of my
> >> mapfile. Initially we had a problem because we had
> compiled mapserver
> >> with INPUT=TIF, make sure you don't have that, and let
> GDAL take care
> >> of it.
> > Thanks alot for the info.
> > Here's my config:
> > [devgeo:/usr/local/wwwsites/apache/devgeo.cciw.ca/cgi-bin/mapserv]$
> > ./ecows -v
> > MapServer version 4.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP
> > OUTPUT=PDF SUPPORTS=PROJ SUPPO RTS=FREETYPE SUPPORTS=WMS_SERVER
> > SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> > SUPPORTS=WFS_CLIENT INPUT=T
> > IFF INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > Can one not force gdal to be used on the layer? I'm not
> sure I'd want
> > to recompile.
> >> MapServer version 4.2.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> >> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> >> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> >> INPUT=EPPL7 INPUT=SDE INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> >> IMAGETYPE PNG24
> >> OUTPUTFORMAT #not sure if this is really necessary
> >> NAME png
> >> MIMETYPE image/png
> >> DRIVER GD/PNG
> >> EXTENSION png
> >> IMAGEMODE PC256
> >> TRANSPARENT FALSE
> >> END
> >> LAYER
> >> NAME "orthobsq"
> >> DATA "014028_0100_010608_l7_08_utm18.tif"
> >> TYPE RASTER
> >> STATUS ON
> >> GROUP ""
> >> PROCESSING "SCALE_1=18,95"
> >> PROJECTION
> >> "init=epsg:26918"
> >> # NAD83 / UTM zone 18N
> >> #<26918> +proj=utm +zone=18 +ellps=GRS80
> +datum=NAD83 +units=m
> >> +no_defs no_defs <>
> >> END
> >> METADATA
> >> "wms_title" "Ortho Photo"
> >> "wms_srs" "EPSG:26918"
> >> "wms_abstract" "Ortho Photo"
> >> "wms_keywordlist" "Ortho Photo"
> >> "wms_extent" "575000 5024000 699000 5110000"
> >> "wms_opaque" "1"
> >> "wms_name" "orthobsq"
> >> "wms_onlineresource" "http://internal/cgi-bin/mapquebec?"
> >> "wms_server_version" "1.1.0"
> >> "wms_stylelist" "default"
> >> "wms_style_default_title" "default"
> >> END
> >> END # LAYER
> >> Hope this helps in some way.
> >> Debbie
> >> From: mapserver-users-admin at lists.gis.umn.edu
> >> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> >> Sent: Tuesday, July 06, 2004 3:18 PM
> >> To: mapserver-users at lists.gis.umn.edu
> >> Subject: [Mapserver-users] WMS Raster problem
> >> Hi,
> >> I have a large file (some 650MB) of type TIFF with .tfw file.
> >> Here's the applicable chunks from my mapfile:
> >> # image format options
> >> OUTPUTFORMAT
> >> NAME GTiff
> >> DRIVER "GDAL/GTiff"
> >> MIMETYPE "image/tiff"
> >> IMAGEMODE RGB
> >> EXTENSION "tif"
> >> END
> >> LAYER
> >> NAME "glc2000"
> >> STATUS ON
> >> GROUP "Global Land Cover"
> >> DATA "glc2000_v1_1.tif"
> >> TYPE RASTER
> >> METADATA
> >> "wms_title" "The Land Cover of the World in the Year 2000"
> >> "wms_group_title" "Global Land Cover"
> >> "wms_abstract" "Global Land Cover"
> >> "wms_keywordlist" "Global Landcover 2000,SPOT Vegetation"
> >> "wms_extent" "-180 -90 180 90"
> >> "wms_opaque" "1"
> >> "wms_name" "glc2000"
> >> "wms_onlineresource" "http://somehost/someurl"
> >> "wms_server_version" "1.1.1"
> >> END
> >> PROJECTION
> >> "init=epsg:4326"
> >> END
> >> END
> >> When I run as WMS, GetCapabilities is okay, but GetMap
> gives me back
> >> a 500.
> >> The error_log just says:
> >> [Tue Jul 06 15:05:17 2004] [error] [client 192.75.68.254]
> Premature
> >> end of script headers: mapserv
> >> Any idea what I'm doing wrong here?
> >> Thanks alot
> >> ..Tom
> >> _______________________________________________
> >> Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> >> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Paul Ramsey
> Refractions Research
> Email: pramsey at refractions.net
> Phone: (250) 885-0632
