[Mapserver-users] Change Projection (e.g. Geographic to Robinson)
Tyler Mitchell
tjmitchell at riverside.bc.ca
Mon Jul 12 11:24:40 EDT 2004
Stefan,
For most folks that are using the CGI version of MapServer, we never get
to see nice object names like ms_newprojectionObj :) So I assume you are
using PHP Mapscript or some other variant. Is that right? I can't help
you there, but I can help with any settings in your map file which is
where I set all my projection info. If you have a map file, send it our
way, or portions of it.
Tyler
mapserver-users-admin at lists.gis.umn.edu wrote on 07/12/2004 07:55:37 AM:
> Hi there,
> it seems that either the "change projection on-the-fly" feature
> isn't widely used or nobody has problems with it. At least, the
> number of threats using the ms_newprojectionObj command is
> relatively small. And the WIKI is empty on the subject of "Projections".
> Could somebody provide me with a working example? I tried to change
> the projection of my data from "geographic" to "robinson" using the
> ms_newprojectionObj object, but it didn't work, and honestly, I am
> a bit confused by the different parameters...
> Thanks for any help,
> Stefan
> _______________________________________
> Stefan Schwarzer
> GIS & Data Management
> UNEP/DEWA/GRID-Geneva
> Chemin des Anemones 11
> CH - 1219 Chatelaine
> Switzerland
> Tel: (+41) 22.917.83.49
> Fax: (+41) 22.917.80.29
> Email: stefan.schwarzer at grid.unep.ch
> Internet: http://geodata.grid.unep.ch/
