[Mapserver-users] WMS client re-projection errors
Tyler Mitchell
tjmitchell at riverside.bc.ca
Tue Jul 13 17:01:15 EDT 2004
Is the image crossing UTM zones?
I recall reading something very recently that says Proj couldn't handle
datum shifts, but may now. I'm not sure that's the issue though.
mapserver-users-admin at lists.gis.umn.edu wrote on 07/13/2004 12:31:20 PM:
> Hi folks,
> I have some shapefiles in UTM, NAD27, Zone 10
> (epsg:26710) which I'm trying to overlay on a WMS
> shaded relief layer from the USGS in Geographic, WGS84
> (epsg:4326). The problem is a noticable distortion on
> the y axis. Features line up at the center of the
> image, but become more and more distorted as you move
> above or below the center-line.
> These three images should capture the idea (keep your
> eye on the peak in relation to the roads around it):
> http://darkstar.rr.nu/download/mapserv1.jpg
> http://darkstar.rr.nu/download/mapserv2.jpg
> http://darkstar.rr.nu/download/mapserv3.jpg
> It is almost as though the WMS image is vertically
> compressed. However, when using a WMS image from
> terraserver (nad83), the map is aligned properly. I am
> running mapserver 4.2.0 on slackware linux with proj
> 4.4.7 & the datum shift files. Perhaps the requested
> WMS extents are not accurate because of the datum
> shift?? Is there something unique to shifting from
> wgs84 to nad27?? Anyone have any ideas?
> The abbreviated mapfile is as follows:
> MAP
> PROJECTION
> "init=epsg:26710"
> # UTM zone 10, Nad27, meters
> END
> LAYER
> NAME "Shaded_relief"
> GROUP "bg"
> STATUS OFF
> TYPE RASTER
> CONNECTIONTYPE WMS
> CONNECTION
> "http://gisdata.usgs.net:80/servlet/com.esri.wms.Esrimap?
> servicename=USGS_WMS_NED&"
> METADATA
> "wms_srs" "EPSG:4326"
> "wms_title" "Shaded Relief"
> "wms_name" "US_NED_Shaded_Relief"
> "wms_server_version" "1.0.0"
> "wms_format" "image/png"
> "wms_group_title" "background"
> END
> PROJECTION
> "init=epsg:4326"
> END
> END
> LAYER
> NAME "Roads"
> STATUS OFF
> DATA "clip1"
> TYPE LINE
> TOLERANCE 2
> DUMP true
> METADATA
> "wms_title" "Klamath Basin Roads"
> "wms_srs" "EPSG:26710"
> "wms_abstract" ""
> "wfs_title" "Klamath Basin Roads"
> "wfs_srs" "EPSG:26710"
> "wfs_abstract" ""
> END
> CLASS
> NAME "Roads"
> STYLE
> SYMBOL 1
> SIZE 2
> COLOR 0 0 0
> END
> END
> END
> END
> Here is a link to a small, clipped shapefile if anyone
> feels inclined to try it out...
> http://darkstar.rr.nu/download/clip1.zip
> ... and the urls to recreate the three sample images
> are:
> http://localhost/cgi-bin/mapserv?
> mode=map&map=/var/www/htdocs/klamath2/klamath2.map&mapext=594418.
> 2128140883+4727975.646318736+602962.0885061937+4733853.
> 945029724&mapsize=610+420&layers=Roads+Shaded_relief
> mode=map&map=/var/www/htdocs/klamath2/klamath2.map&mapext=594411.
> 1981378223+4730115.122579895+602955.0738299277+4735993.
> 421290884&mapsize=610+420&layers=Roads+Shaded_relief
> 1981378224+4726172.874518348+602955.0738299278+4732051.
> 173229337&mapsize=610+420&layers=Roads+Shaded_relief
> Thanks... Any ideas are greatly appreciated!!
> Matthew Perry
> Humboldt State University
> Natural Resources Planning
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
