[Mapserver-users] Logging WMS client requests
    Matthew Perry
    mtperry78 at sbcglobal.net
    Tue Jul 13 17:52:50 PDT 2004
Hi folks,
 I was wondering how I would log the requests that
mapserver (as a wms-client) sends to a remote
wms-server. I am having issues with shifting datums on
a WMS image and need to examine the BBOX mapserver is
requesting.
In my mapserver log, all I get is:
Tue Jul 13 .... ,normal execution
Since I'm not getting an error back from the remote
server, MS_ERRORFILE doesn't do me much good, correct?
I remember seeing a thread about this before but I was
unable to find the solution.
Any ideas?
Matthew Perry
Humboldt State University
Natural Resources Planning
--- Paul Ramsey <pramsey at refractions.net> wrote:
> My guess is that the act of stuffing the WMS through
> a datum transform
> is messing things up... what happens if you set your
> output to 26910,
> and set the projection object in your WMS layer to
> be 4269 (NAD 83
> lat/lon) instead of 4236? (ie, pretend your image is
> in NAD83, so that
> mapserver does not attempt to datum shift it.
> If things still fail, then it is time to turn up the
> logging and see
> what the WMS requests to USGS are. Your suspicion
> that Mapserver might
> be asking for incorrect bounding boxes from USGS
> when doing transforms
> might be correct.
> Paul
> Matthew Perry wrote:
> > Paul,
> >  Thanks for the response. I tried some of your
> > suggestions....
> >>Change your output projection to 26910, so that
> your
> >>vectors are being
> >>datum shifted but your image is not.
> > This still requires the WMS image to be
> transformed
> > from wgs84 to nad83. Predictably, the image is
> still
> > mis-aligned.
> >>If things are still not working, try setting your
> >>4326, so your vectors are being tranformed into
> the
> >>native projection of
> >>your raster.
> > Eureka! The layers are aligned regardless of their
> > position on the image...
http://darkstar.rr.nu/cgi-bin/mapserv?mode=map&map=/var/www/htdocs/klamath2/klamath2.map&mapext=-121.848094294579+42.7195258065662+-121.742700618268+42.7713535046386&mapsize=610+420&layers=Roads+Shaded_relief
> > Unfortunately, for a number of reasons, I need to
> keep
> > the map in the native projection of my vector
> layers.
> > Based on my wild guess, It seems as if mapserver
> is
> > not requesting the correct bounding box from the
> WMS
> > when the datum shift (wgs84->nad27/nad83) is
> involved.
> > Would this be a correct assumption?
> > Matthew Perry
> > Humboldt State
> >>>Hi folks,
> >>>  I have some shapefiles in UTM, NAD27, Zone 10
> >>>(epsg:26710) which I'm trying to overlay on a WMS
> >>>shaded relief layer from the USGS in Geographic,
> >>WGS84
> >>>(epsg:4326). The problem is a noticable
> distortion
> >>on
> >>>the y axis. Features line up at the center of the
> >>>image, but become more and more distorted as you
> >>move
> >>>above or below the center-line.
> >>>These three images should capture the idea (keep
> >>your
> >>>eye on the peak in relation to the roads around
> >>it):
> >>>http://darkstar.rr.nu/download/mapserv1.jpg
> >>>http://darkstar.rr.nu/download/mapserv2.jpg
> >>>http://darkstar.rr.nu/download/mapserv3.jpg
> >>>It is almost as though the WMS image is
> vertically
> >>>compressed. However, when using a WMS image from
> >>>terraserver (nad83), the map is aligned properly.
> >>I am
> >>>running mapserver 4.2.0 on slackware linux with
> >>proj
> >>>4.4.7 & the datum shift files. Perhaps the
> >>requested
> >>>WMS extents are not accurate because of the datum
> >>>shift?? Is there something unique to shifting
> from
> >>>wgs84 to nad27?? Anyone have any ideas?
> >>>The abbreviated mapfile is as follows:
> >>>MAP
> >>>  PROJECTION
> >>>    "init=epsg:26710"
> >>>    # UTM zone 10, Nad27, meters
> >>>  END
> >>>  LAYER
> >>>    NAME "Shaded_relief"
> >>>    GROUP "bg"
> >>>    STATUS OFF
> >>>    TYPE RASTER
> >>>    CONNECTIONTYPE WMS
> >>>    CONNECTION
"http://gisdata.usgs.net:80/servlet/com.esri.wms.Esrimap?servicename=USGS_WMS_NED&"
> >>>    METADATA
> >>>      "wms_srs"    "EPSG:4326"
> >>>      "wms_title"    "Shaded Relief"
> >>>      "wms_name"    "US_NED_Shaded_Relief"
> >>>      "wms_server_version"    "1.0.0"
> >>>      "wms_format"    "image/png"
> >>>      "wms_group_title" "background"
> >>>    END
> >>>    PROJECTION
> >>>      "init=epsg:4326"
> >>>    END
> >>>  END
> >>>  LAYER
> >>>    NAME "Roads"
> >>>    STATUS OFF
> >>>    DATA "clip1"
> >>>    TYPE LINE
> >>>    TOLERANCE 2
> >>>    DUMP true
> >>>    METADATA
> >>>      "wms_title"    "Klamath Basin Roads"
> >>>      "wms_srs"    "EPSG:26710"
> >>>      "wms_abstract" ""
> >>>      "wfs_title"   "Klamath Basin Roads"
> >>>      "wfs_srs"    "EPSG:26710"
> >>>      "wfs_abstract" ""
> >>>    END
> >>>    CLASS
> >>>      NAME "Roads"
> >>>      STYLE
> >>>        SYMBOL 1
> >>>        SIZE 2
> >>>        COLOR 0 0 0
> >>>      END
> >>>    END
> >>>  END
> >>>END
> >>>Here is a link to a small, clipped shapefile if
> >>anyone
> >>>feels inclined to try it out...
> >>>http://darkstar.rr.nu/download/clip1.zip
=== message truncated ===
More information about the MapServer-users
