[Mapserver-users] WMS client re-projection errors
Arnulf Christl
arnulf.christl at ccgis.de
Wed Jul 14 04:13:50 EDT 2004
Tyler Mitchell wrote:
>>I have noticed that the USGS WMS is slightly evil in
>>that if you fudge the extents on a GetMap request, the
>>image will be warped instead of recalculating a
>>proportional bounding box.
>>What is does the WMS standard say about this?? What
>>behavior is mapserver expecting??
>A side question - but how do you make sure you know that a host is WMS
>compliant and to what degree?
Check it with deegree - its Open Source and it is the official OGC WMS
1.1.1 reference implementation.
The only way to check whether a service is WMS compliant is to go check
with the OGC website which hosts a list of "compliant" and
"implementing" services.
http://www.opengis.org/resources/?page=products
"Compliant" is the real thing, "Implementing" may lack or fail on some
of the testing criteria! Most not-compliant services have problems
reprojecting or returning non-square pixels (see other emails).
How to get the compliancy stamp can be found out here:
http://www.opengis.org/resources/?page=testing
I will not comment on whether this is a good procedure or not but it
seems that currently it is the only way to find out about compliancy. As
an alternative you can find several interoperability testbeds in the net
but most have a rather commercial backgound and may be "bend" some
facts. Therefore we plan to set up yet another interoperability testbed
with Mapbender which is open to everybody (bend maps as you like). Maybe
we will need to set up an interoperability testbed for the
interoperability testbeds - who knows...
Cheers, Arnulf.
>Tyler
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
CCGIS Christl & Stamm GbR
http://www.ccgis.de
http://www.mapbender.org
Service: +49 (0)228 90826 0
Direct: +49 (0)228 90826 23
Fax: +49 (0)228 90826 11
Siemensstraße 8
53121 Bonn
GERMANY
