[Mapserver-users] Error on import mapscript in Python with Mapserver 4.2.1
Sean Gillies
sgillies at frii.com
Wed Jul 14 12:04:36 EDT 2004
On Jul 14, 2004, at 9:54 AM, Björn Platzen wrote:
> Hi Sean,
>> gdImageSetClip was added to GD in version 2.0.12. I suspect that you
>> have an early version (before 2.0.12) of GD on your system that is
>> interfering with the GD 2.0.27 you want to use.
> Maybe you're right. I have also a mapserver 3.6.5 running wich is
> compiled against gd-2.0.7. This gd is under /usr/lib/ while the new
> compiled gd-2.0.27 is under /usr/local/lib/.
> Would it be a way to compile Mapserver with
> --with-gd=static,/path/to/gd-2.0.27
> and then rebuild mapscript??
> Thanks ,
> Bjoern.
Bjoern, I don't statically link and can't say for sure, but I think
this will work.
You will also need to make a small edit to the setup.py file. There
will be an example in the script of how to statically link mapscript
to GD.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
