[Mapserver-users] JOIN problem
Rebecca Colwell
colwell at geog.umn.edu
Wed Jul 14 12:38:54 EDT 2004
Hey Randy,
Yes, it displays my US shapefile when I comment out that line. What
does this tell you?
Thanks!
~Becky
Randy James wrote:
> Hi
> Will it work if you do not filter it by 'Disfchmt_R' ?
> Randy
> --- Rebecca Colwell <colwell at geog.umn.edu> wrote: > Hi,
>>I'm trying to work through building one of my first .map
>>files, and have
>>hit a wall. I can't seem to figure out how to do a
>>one-to-one join. I
>>keep getting the error messages:
>>msDrawMap(): Image handling error. Failed to draw layer
>>named 'states'.
>>msDBFGetItemIndex(): DBASE file error. Item 'Disfchmt_R'
>>not found.
>>I triple checked the .dbf I'm trying to join, and that is
>>the name of
>>the attribute field I want to access.
>>Below is my short bit of code so far. I would be so
>>thankful if anyone
>>could guide me in the right direction on how to get it to
>>work.
>>~Becky
>>MAP
>> IMAGETYPE PNG24
>> EXTENT -2153561.581984760 4847233.565621579
>>2641846.236294404
>>-6178805.564371807
>> SIZE 800 500
>> SHAPEPATH "data"
>> IMAGECOLOR 203 201 226
>> PROJECTION
>> "proj=laea"
>> "ellps=clrk66"
>> "lat_0=45"
>> "lon_0=-100"
>> END
>> # Start of LAYER DEFINITIONS
>> LAYER # States polygon layer begins here
>> NAME states
>> DATA STATES
>> STATUS DEFAULT
>> TYPE POLYGON
>> PROJECTION
>> "init=epsg:4326"
>> END
>> JOIN
>> NAME "Felon Ethnicity"
>> TABLE "data/FelonEthnicity.dbf"
>> FROM "STATE_NAME"
>> TO "STATE"
>> TYPE single
>> END #Join
>> CLASS
>> NAME "<21%"
>> EXPRESSION ('[Disfchmt_R]' <= .021)
>> COLOR 242 240 247
>> OUTLINECOLOR 200 200 200
>> COLOR 232 232 232
>> OUTLINECOLOR 32 32 32
>> END
>> END # States polygon layer ends here
>> # End of LAYER DEFINITIONS
>>END # end of map file/object
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> ______________________________________________________________________
> Post your free ad now! http://personals.yahoo.ca
