[Mapserver-users] OGC WMS GetfeatureInfo - MapServer 4.2
Daniel Morissette
dmorissette at dmsolutions.ca
Thu Jul 15 17:54:07 EDT 2004
Julien, Heryk wrote:
> So I'm passing the same information in two different parameters
> (Query_Layers and Layers)!
> In table 9 (The Parameters of a GetFeatureInfo Request p.40) of the OGC
> specs (http://www.opengis.org/docs/01-068r3.pdf) the layers param is not
> needed in a GetFeatureInfo request.
A GetFeatureInfo is performed by clicking on a map produced using a
GetMap call, so you need to indicate to the server which map you clicked
on, that's why you need to carry the GetMap requests.
The parameters listed in table 9 are only those you need to add on top
of the corresponding GetMap parameters. This is indicated, but maybe not
clearly enough, in 7.3.1 page 39:
"Because the WMS protocol is stateless, the GetFeatureInfo request
indicates to the WMS what map the user is viewing by including most
of the original GetMap request parameters (all but VERSION and
REQUEST)."
Of course LAYERS may be considered redundant in this context, but there
may be contexts that I can't think of right now where it is useful, so
instead of documenting a bunch of exceptions the spec just says: "start
with the GetMap parameters, and add the GetFeatureInfo parameters on top."
Note that in QUERY_LAYERS you should only pass the layers you want to
query, this will often be a subset of the LAYERS parameter.
HTH
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
