[Mapserver-users] Mapserver Postgis connection issues
Swaminathan, Gayathri
gayathri at ou.edu
Fri Jul 16 16:44:30 EDT 2004
Ok I tried shp2img... As follows:
C:\Inetpub\cgi-bin>shp2img -m c:\Inetpub\wwwroot\athena\mapODOC.map -o c:\out.png -l sqlSewerline
and it returns a blank image with my IMAGEBACKGROUND set in the mapfile.
sqlSewerline is my postgis layer.
The above command works fine for shape files though and renders out.png with parcels...
> -----Original Message-----
> From: Tyler Mitchell [mailto:tjmitchell at riverside.bc.ca]
> Sent: Friday, July 16, 2004 3:29 PM
> To: Swaminathan, Gayathri
> Cc: Vladimir Guzmán; Kathi Koebke;
> mapserver-users at lists.gis.umn.edu;
> mapserver-users-admin at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Mapserver Postgis connection issues
> > If I added a Postgis layer however..I am having the mapserver cgi
> > run indefinetely and locking up.
> Are you using any sort of java interface in your web page?
> I would try to debug by using the command line shp2img
> command instead.
> See if it throws any errors.
