[Mapserver-users] strange results when displaying grid
Ted Quinby
quinby at earthit.com
Fri Jul 16 18:03:36 EDT 2004
I have an Arc/Info Binary Grid I'm trying to display in Mapserver. When
displayed in ArcView or ArcMap, the grid is fine -- pixel values ranging
from 1 to 8 and all in the right place.
However, when displaying this grid in Mapserver, a strange thing
happens. A small 32 x 32 pixel square appears in the eastern portion of
the grid. In further evaluating this 32 x 32 pixel square, pixels that
should have a value of 3 are being drawn as if the pixel value was 1 and
pixels that should have a value of 4 are being drawn as 0. This only
occurs within this square -- all other pixel values are drawn correctly.
I ran gdalinfo on this grid and got the following results:
Driver: AIG/Arc/Info Binary Grid
Coordinate System is `'
Origin = (570771.937500,314684.593750)
Pixel Size = (1.00000000,-1.00000000)
Corner Coordinates:
Upper Left ( 570771.938, 314684.594)
Lower Left ( 570771.938, 314066.594)
Upper Right ( 571624.938, 314684.594)
Lower Right ( 571624.938, 314066.594)
Center ( 571198.438, 314375.594)
Band 1 Block=32x32 Type=Byte, ColorInterp=Undefined
Min=1.000 Max = 8.000
NoData Value = 255
This leads me to believe that the values indeed range from 1 to 8 as
displayed in the ESRI tools. Why, when drawn in Mapserver, are a select
group of 4 values being drawn as 0? There should be no 0 values in the
grid? Why are a select number of 3 values being switched to 1?
The plot thickens -- when I convert the grid to a tif and display the tif
in Mapserver, all values are displayed correctly.
I know the simple solution is just to be happy with the tif -- don't use
the grid. However, I'm curious what's going on here.
Am I dealing with a corrupted grid somehow or is Mapserver
reading/displaying a valid grid incorrectly?
Anybody experience something similar or have any debugging thoughts?
Details for the raster layer in the mapfile are as follows:
LAYER
NAME "em"
GROUP "geophys_raster"
METADATA
"title" "Electromagnetic Conductivity (mS/m)"
END
STATUS OFF
DATA "geophys/emgrid"
#DATA "geophys/emtest.tif"
TYPE RASTER
CLASSITEM "[pixel]"
CLASS
NAME 'Other'
EXPRESSION ( [pixel] == 0 )
COLOR 0 0 0
END
CLASS
NAME '-3 - 20'
EXPRESSION ( [pixel] == 1 )
COLOR 23 0 220
END
CLASS
NAME '20 - 25'
EXPRESSION ( [pixel] == 2 )
COLOR 20 0 254
END
CLASS
NAME '25 - 30'
EXPRESSION ( [pixel] == 3 )
COLOR 85 70 254
END
CLASS
NAME '30 - 35'
EXPRESSION ( [pixel] == 4 )
COLOR 165 166 254
END
CLASS
NAME '35 - 40'
EXPRESSION ( [pixel] == 5 )
COLOR 255 255 255
END
CLASS
NAME '40 - 45'
EXPRESSION ( [pixel] == 6 )
COLOR 254 160 160
END
CLASS
NAME '45 - 50'
EXPRESSION ( [pixel] == 7 )
COLOR 254 70 70
END
CLASS
NAME '> 78'
EXPRESSION ( [pixel] == 8 )
COLOR 255 0 0
END
END
Thanks in advance for your response!
Ted
