[Mapserver-users] Mapserver Postgis connection issues
Merlos
merlos at tsc.uvigo.es
Sat Jul 17 09:00:55 EDT 2004
Ups! I made a mistake. The correct name of the dll is libpq.dll
Sorry.
On Saturday 17 July 2004 13:39, Merlos wrote:
> Hi!
> These days I was wondering if there was any postgresql with postgis for
> windows already compiled, so when I saw your link I downloaded it.
> After unpackaging and saving it in the c:\pgsql75win directory I tried to
> run initdb.bat, but it throw an error. Some procedure call was not found on
> pqsql.dll, I looked at the mapserver binaries dll and I noticed that it
> included a pqsql with a 65 KB size (witch I already copied into
> C:\windows\system32) and on C:\pgsql75win\lib there was another pgsql.dll,
> this time with a size of 129KB, so what i did was the bigger one on
> system32, now postgresql is running.
> I haven't tested if mapserver querys work (have to create the DBs,etc..)
> but maybe your problem is related to this.
> I'm trying with WinDoS XP home/apache1.3/php4.3.7/mapserver4.2 binaries
> package
> Regards. Juan
> On Friday 16 July 2004 22:44, Swaminathan, Gayathri wrote:
> > Ok I tried shp2img... As follows:
> > C:\Inetpub\cgi-bin>shp2img -m c:\Inetpub\wwwroot\athena\mapODOC.map -o
> > c:\out.png -l sqlSewerline
> > and it returns a blank image with my IMAGEBACKGROUND set in the mapfile.
> > sqlSewerline is my postgis layer.
> > with parcels...
> > > -----Original Message-----
> > > From: Tyler Mitchell [mailto:tjmitchell at riverside.bc.ca]
> > > Sent: Friday, July 16, 2004 3:29 PM
> > > To: Swaminathan, Gayathri
> > > Cc: Vladimir Guzmán; Kathi Koebke;
> > > mapserver-users at lists.gis.umn.edu;
> > > mapserver-users-admin at lists.gis.umn.edu
> > > Subject: Re: [Mapserver-users] Mapserver Postgis connection issues
> > > > If I added a Postgis layer however..I am having the mapserver cgi
> > > > run indefinetely and locking up.
> > > Are you using any sort of java interface in your web page?
> > > I would try to debug by using the command line shp2img
> > > command instead.
> > > See if it throws any errors.
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
http://www.merlos.biz
