[Mapserver-users] Changing Colors in Map !!
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Jul 17 10:26:46 EDT 2004
Stephen Woodbridge wrote:
> I think I may have created a feature and inserted a one pixel dot on the
> map that gets covers by later layers. Play with it and if you have a
> problem let me know and I can dig through old mapfiles and find out how
> I did it.
Here are some examples of preserving the colors in a symbol that were
changing. The big problem with this approach is that it uses up a lot of
layers, so you might try using one layer with lots of classes, but I'm
not sure it that will work.
The bug for this problem is:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=306
I just updated it with this information.
## dummy layer to protect symbol colors from changing
LAYER
NAME "color_symbol"
STATUS DEFAULT
TYPE point
TRANSFORM false
FEATURE
POINTS
1 1
END
END
CLASS
SYMBOL "color_symbol"
COLOR 0 0 0
END
END
## protect other colors
LAYER
NAME blue
STATUS DEFAULT
TYPE point
TRANSFORM false
FEATURE
POINTS
1 1
END
END
CLASS
COLOR 0 0 255
END
END
LAYER
NAME green
STATUS DEFAULT
TYPE point
TRANSFORM false
FEATURE
POINTS
1 1
END
END
CLASS
COLOR 8 206 107
END
END
