[Mapserver-users] Help loading PHP Dlls
    ANDY CANFIELD
    andy_canfield at hotmail.com
    Sun Jul 18 11:34:49 PDT 2004
I'm not sure then if your Ini points to the correct location. Apparently you
aren't the first to experience this. What version of php are you using and
what version of mapscript is it? It looks like you are running Apache what
is the OS it's running on? Also if you want to see how many other people
have had the same problem with mapscript and Apache go to the archives
search page located here:
http://mapserver.gis.umn.edu/cgi-bin/wilma/mapserver-users
and in the search box enter:
Unable;load;library
Apparently you are not alone in this. I don't know enough about Apache to be
able to give you any more info than that. Perhapse one of the people who had
this problem before will pipe up and let you know what they did to fix it.
>From: TOH CZ <cz_toh at yahoo.com>
>To: mapserver-users at lists.gis.umn.edu
>Subject: RE: [Mapserver-users] Help loading PHP Dlls
>Date: Sun, 18 Jul 2004 17:19:58 +0100 (BST)
>This is the line which I indicated the extension
>directory
>extension_dir = "C:\phpWin32\extensions\"
>It should be correct
>___________________________________________________________ALL-NEW Yahoo!
>Messenger - sooooo many all-new ways to express yourself
>http://uk.messenger.yahoo.com
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
_________________________________________________________________
Is your PC infected? Get a FREE online computer virus scan from McAfee®
Security. http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
More information about the MapServer-users
