[Mapserver-users] Need Urgent Help on PHP/MapScript >> ms_newPointObj()
Ishrar Hussain
ishrarh at yahoo.com
Mon Jul 19 11:52:02 EDT 2004
Please give me an example code showing how to use
PointObj class, i.e. ms_newPointObj(), to dynamically
draw a point over an already created instance of
MapObj, which have been instantiated with a static
.map file.
Using Maplab, I have created my web mapping
application, which successfully published my shape
files in 4 layers. The map is now static. And over
this map, I need to draw with PHP/MapScript a new
layer that will hold one dynamic point, whose
coordinates I will be retrieving from a database using
PHP. (I am editing the drawmap.php file in the wrapper
folder for this.)
Note that, I don't want to have this new layer
definition in my map file, which will make the layer
static. I also cannot use any database connection in
the mapfile (postgis or postgre or mygis). Thus,
PHP/MapScript's PointObj is my only choice.
So, if possible, let me know whether PointObj can be
used to dynamically draw a point like this over a
MapObj, which is already instantiated with a map file
having 4 layer definitions.
Any detailed example code showing how to use PointObj
will do.
Thank you.
- Ishrar
__________________________________
Do you Yahoo!?
Vote for the stars of Yahoo!'s next ad campaign!
http://advision.webevents.yahoo.com/yahoo/votelifeengine/
