[Mapserver-users] Multiple DSN Problem
Frank Warmerdam
warmerdam at pobox.com
Tue Jul 20 09:49:05 EDT 2004
D'cruz,Steven [Ontario] wrote:
> Hi there,
> I was wondering if anyone has any experience with executing
> select statements using two different DSNs simultaneously. For my work,
> I require functionality similar to the following: "select a.* from
> tablename1 a, tablename2 b where a.id=b.id and b.filter='t'" , where
> tablename1 and tablename2 are from 2 DIFFERENT DSNs. Both DSNs are to
> be accessed via a realtime connection to a MS Access 2000 database from
> a linux host via the FREETDS drivers. I currently have both DSNs
> working independently in 2 test layers (with no errors) using the
> required fields. Here's the .ovf file used for the selection queue from
> the MS Access 2000 databases.
Steven,
Are the two tables you are interested in within the same MS-SQL database?
If so, you should be able to just do your join in a single SrcSQL statement.
Any SQL that the remote ODBC database supports can be in the SrcSQL
statement.
OGR SQL also has a built-in join syntax when you are working against
non-SQL enabled databases that allows accessing tables from different
datasources but that would be hard to make kick in when using stuff over
ODBC.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
