[Mapserver-users] Write a comment with python mapscript to the mapfile ?
Sean Gillies
sgillies at frii.com
Wed Jul 21 09:38:28 EDT 2004
On Jul 21, 2004, at 5:15 AM, Jan Schüngel wrote:
> Hi,
> I am writing a mapfile with mapscript and that all works fine, but now
> i want to
> write some lines with comments like "# file automatically created by
> program xyz
> to the beginning of the ne created file.
> Is there any possibility to do this with python mapscript ?
> Thanks
> Jan S.
Jan,
None of the mapscript modules can output comments.
What you *can* do is use the MAP metadata for this purpose. If you are
using
mapserver versions 4.2 or older, the syntax would be something like
the_map.setMetaData('Created By', 'Program XYZ')
or in 4.3
the_map.web.metadata.set('Created By', 'Program XYZ')
then, after you save the map, you should have a mapfile that includes
WEB
METADATA
"Created By" "Program XYZ"
I prefer this way because it will give you the future capablility of
programmatically accessing the metadata instead of trapping it in
comments.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
