[Mapserver-users] Re: MapServer 4.2.1 Installation on FreeBSD 4.9
Benjamin Thelen
thelen at ccgis.de
Wed Jul 21 10:32:26 EDT 2004
Hello,
We face the same problem at the moment. UMN-MapServer 4.2.x requires
at least gdal-1.1.9. There is a new gdal-1.2.0 port which has been
commited just a few weeks ago, so you have to cvsup your portstree and
update gdal (use "portupgrade"). But I hacked the gdal-1.1.8 Makefile
a little to force gdal-1.1.8 to refere to the external pnglib (1.2.5),
because apache had problems (internal server error) with the old one,
delivered together with gdal-1.1.8 (1.0.6!). That hack does not work
for gdal-1.2.0 (compiling stops with an error)! So I have to use the
internal lib and hope that apache comes a long with it.
But be careful updating your production environment, because after
updating the portstree, afterwoods the system and compiling mapserver
4.0.2 again, ms 4.0.2 cannot read tifs anymore (4.2 does). I recommend
testing all this on a non production server!
Regards,
Benjamin Thelen
CCGIS GbR - Bonn
http://www.ccgis.de
Siemensstraße 8
53121 Bonn
Germany
Tel: ++49 (0) 228 90826 15
Fax: ++49 (0) 228 90826 11
Weßling, Achim wrote:
> Hallo,
> I just tried to update my MS-Installtion from 4.0.2 to 4.2.1 on a FreeBSD
> 4.9 Box. With the last Versions of MS I used the following script to
> configure MS:
> #!/bin/sh
> ./configure --with-xpm=/usr/X11R6/lib --with-gd=/usr/local --with-gdal
> --with-ogr --with-proj=/usr/local --with-jpeg=/usr/local
> --with-png=/usr/local --without-tiff --with-libiconv=/usr/local --with-zlib
> --with-curl --with-freetype
> --with-php=/usr/ports/www/php4-cgi/work/php-4.3.3 --with-wmsclient
> --with-wfs --with-wfsclient --with-postgis --enable-runpath
> The output of the script above and gmake follows:
> ./configure-umn.sh
> checking for gcc... gcc
> checking for C compiler default output... a.out
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ANSI C... none needed
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking for ranlib... ranlib
> checking for flex... flex
> checking for yywrap in -lfl... yes
> checking lex output file root... lex.yy
> checking whether yytext is a pointer... yes
> checking for bison... bison -y
> checking if compiler supports -R... yes
> checking for exp in -lm... yes
> checking for __gxx_personality_v0 in -lstdc++... no
> checking how to run the C preprocessor... gcc -E
> checking for egrep... grep -E
> checking for ANSI C header files... yes
> checking for strcasecmp... yes
> checking for strncasecmp... yes
> checking for strdup... yes
> configure: checking where FreeType 2.x is installed......
> checking for freetype-config... /usr/local/bin/freetype-config
> using libfreetype from -L/usr/local/lib -lfreetype -lz
> checking for FT_Init_FreeType in -lfreetype... no
> using libfreetype -L/usr/local/lib -lfreetype -lz from system libs.
> configure: checking where Zlib is installed......
> checking for zlibVersion in -lz... yes
> using libz from system libs.
> configure: checking where PNG is installed......
> using libpng from -L/usr/local/lib -lpng
> configure: checking whether we should include JPEG support......
> using libjpeg from system -L/usr/local/lib -ljpeg
> configure: checking where libXpm is installed......
> using libXpm from -L/usr/X11R6/lib -lXpm -lX11
> configure: checking where libiconv is installed......
> using libiconv from -L/usr/local/lib -liconv
> configure: checking for GD 2.0.12 or higher......
> checking for gdImageSetAntiAliased in -lgd... yes
> using libgd 2.0.12 (or higher) from -L/usr/local/lib -lgd
> -L/usr/local/lib -ljpeg -L/usr/local/lib -lfreetype -lz -L/usr/local/lib
> -lpng -lz -L/usr/X11R6/lib -lXpm -lX11
> checking for gdImageGif in -lc... yes
> checking for gdImagePng in -lc... yes
> checking for gdImageJpeg in -lc... yes
> checking for gdImageWBMP in -lc... yes
> checking for gdImageStringFT in -lc... yes
> checking for gdImageGifPtr in -lc... yes
> using GD ( -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
> -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR) from /usr/local.
> configure: checking whether we should include PDF support......
> checking for PDF_setlinewidth in -lpdf... no
> checking for PDF_setrgbcolor in -lpdf... no
> checking for PDF_moveto in -lpdf... no
> checking for PDF_curveto in -lpdf... no
> checking for PDF_show_xy in -lpdf... no
> libpdf not found... PDF support not included.
> configure: checking whether we should include EPPL7 support......
> including EPPL7 support.
> configure: checking whether we should include PROJ.4 support......
> checking for pj_transform in -lproj... yes
> checking for pj_latlong_from_proj in -lproj... yes
> using PROJ.4 from /usr/local.
> configure: checking whether we should include thread safe support......
> thread safe support disabled.
> configure: checking whether we should include ESRI SDE support......
> ESRI SDE support not requested.
> configure: checking whether we should compile in MPATROL support......
> MPATROL support not requested.
> configure: checking whether we should include OGR support......
> checking for gdal-config... /usr/local/bin/gdal-config
> OGR enabled (-DUSE_OGR).
> checking if GDAL support requested... yes
> checking checking ms JPEG output... no we, have GDAL available.
> configure: checking whether we should include TIFF support......
> disabled by --without-tiff
> checking if PostGIS support requested... yes
> checking for pg_config... /usr/local/bin/pg_config
> yes, user supplied pg_config
> checking if MyGIS support requested... no
> checking if OracleSpatial support requested... no
> checking if MING/Flash support requested... no
> configure: checking whether we should include WMS Server support......
> OGC WMS compatibility enabled (-DUSE_WMS_SVR).
> configure: checking whether we should include WFS Server support......
> OGC WFS Server support enabled (-DUSE_WFS_SVR).
> configure: checking whether we should include WMS Client Connections
> support......
> configure: checking whether we should include WFS Client Connections
> support......
> configure: checking for curl-config...
> checking for curl-config... /usr/local/bin/curl-config
> found libcurl version 7.10.7
> OGC WMS Client Connections enabled (-DUSE_WMS_LYR).
> OGC WFS Client Connections enabled (-DUSE_WFS_LYR).
> configure: checking HTTPD server (Apache) version...
> checking for httpd... /usr/local/sbin/httpd
> /usr/local/sbin/httpd version is Apache/1.3.28 (1003028).
> Compiling with -DIGNORE_MISSING_DATA.
> configure: checking whether we should enable debug features......
> configure: checking for PHP/MapScript module options......
> checking for g++ -shared ... yes
> using 'g++ -shared' for dynamic linking
> checking for location of config.h or php_config.h...
> /usr/ports/www/php4-cgi/work/php-4.3.3/main/php_config.h
> checking whether we have PHP3 or PHP4... -DPHP4
> checking whether we should use PHP's regex... no
> PHP/MapScript module configured.
> configure: creating ./config.status
> config.status: creating Makefile
> config.status: creating mapscript/php3/Makefile
> lni90235# gmake
> gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H
> -DUSE_WMS_SVR -DUSE_WMS_LYR -DUSE_WFS_SVR -DUSE_WFS_LYR -DUSE_GD_GIF
> -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR
> -DUSE_OGR -DUSE_GDAL -DUSE_POSTGIS -I/usr/local/include
> -I/usr/local/include -I/usr/local/include -I/usr/local/include
> -I/usr/local/include -I/usr/local/include shp2img.o -L. -lmap
> -L/usr/local/lib -lgd -L/usr/local/lib -ljpeg -L/usr/local/lib -lfreetype
> -lz -L/usr/local/lib -lpng -lz -L/usr/X11R6/lib -lXpm -lX11
> -lpng -lz -L/usr/X11R6/lib -lXpm -lX11 -L/usr/local/lib -lproj
> -L/usr/local/lib -ljpeg -L/usr/local/lib -lgdal -L/usr/local/lib -lpq
> -L/usr/local/lib -lcurl -rpath=/usr/lib:/usr/local/lib -lz -lssl -lcrypto
> -lz -lm -o shp2img
> ./libmap.a(mapogr.o): In function `ogrGeomPoints(OGRGeometry *, shapeObj
> mapogr.o(.text+0x174): undefined reference to
> `OGRPolygon::getNumInteriorRings(void)'
> mapogr.o(.text+0x1e8): undefined reference to
> `OGRGeometryCollection::getNumGeometries(void)'
> mapogr.o(.text+0x3a4): undefined reference to
> ./libmap.a(mapogr.o): In function `ogrGeomLine(OGRGeometry *, shapeObj *,
> int)':mapogr.o(.text+0x4e7): undefined reference to
> mapogr.o(.text+0x53f): undefined reference to
> gmake: *** [shp2img] Error 1
> lni90235#
> Mit freundlichem Gruß
> Achim Weßling
> INFOKOM Gütersloh AöR
> Fachbereich Technische Anwendungen
> Herzebrocker Str. 140
> 33334 Gütersloh
> Tel.: 05241/85-2926
> Achim.Wessling at gt-net.de
> http://www.infokom-gt.de
