[Mapserver-users] JBOX ERROR and more
Javier Castillejo Montes
jcastil1 at tragsa.es
Tue Jul 27 02:35:38 EDT 2004
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C473A3.F084C2F4
Content-Type: text/plain;
charset="iso-8859-1"
Hi!
Well let me explain the situation... I'm using Mapserver 4.2, w2k, IE 6 and
IIS.
I use this line to start the map...
//[host]/script/mapserv.exe?map=[rutamapa]/FrameMapa.map&layer=penin28
&layer=autonomias&layer=CCAALabel&mode=browse&Zoom=&WhichButton=Han&ZoomAct=
which is set at the load time and each time a press the button "reset the
map". It doesn't matter how many times I zoom in and out, how mani times I
drag the image... it's only happend at the load time and at the "reset the
map" click.
Hope this will help!
-----Mensaje original-----
De: Richard Greenwood [mailto:rich at greenwoodmap.com]
Enviado el: martes, 27 de julio de 2004 4:03
Para: Javier Castillejo Montes
CC: mapserver-users at lists.gis.umn.edu
Asunto: Re: [Mapserver-users] JBOX ERROR and more
Javier Castillejo Montes wrote:
> Hi all!
> I'm using jbox and it works almost perfect. Sometimes(i don't know when) I
> have "Applet error. IOException PngImage" error, but I just clic where the
> map is suppose to be drawn and it's appears with oput any problem... Does
> anyone know how to avoid this error?
I would love to help with any jBox problems, but you need to give us a
better idea of when the problem occurs and the code that causes to to
happen. For example, what browser? what Java Virtual Machine (VM)? Does
it happen right when the pages has loaded, or after many zooms and pans?
> I asked the next question some time ago as I couldn't solve the promen I
> just aboid the step, but now my boss ask me about to add this step so...
> here it is the question, as I couldn't solve it yet... I have a map
country,
> and it has been divided into small parts. Its parts should have been drawn
> with different colors... as I can find differents parts in differents
> countries I would like to know how to set for each part a color.
You are more likely to get an answer to this question if you post it as
a separate email with an appropriate subject.
Regards,
Richard Greenwood
www.greenwoodmap.com
Content-Type: text/html;
Content-Transfer-Encoding: quoted-printable
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<META NAME=3D"Generator" CONTENT=3D"MS Exchange Server version =
5.5.2650.12">
<TITLE>RE: [Mapserver-users] JBOX ERROR and more</TITLE>
</HEAD>
<BODY>
<P><FONT SIZE=3D2>Hi!</FONT>
<BR><FONT SIZE=3D2>Well let me explain the situation... I'm using =
Mapserver 4.2, w2k, IE 6 and IIS.</FONT>
</P>
<P><FONT SIZE=3D2>I use this line to start the map...</FONT>
<BR> <FONT =
SIZE=3D2>//[host]/script/mapserv.exe?map=3D[rutamapa]/FrameMapa.map&=
layer=3Dpenin28 =
&layer=3Dautonomias&layer=3DCCAALabel&mode=3Dbrowse&Zoom=
=3D&WhichButton=3DHan&ZoomAct=3D</FONT></P>
<P><FONT SIZE=3D2>which is set at the load time and each time a press =
the button "reset the map". It doesn't matter how many =
times I zoom in and out, how mani times I drag the image... it's only =
happend at the load time and at the "reset the map" =
click.</FONT></P>
<P><FONT SIZE=3D2>Hope this will help!</FONT>
</P>
<BR>
<BR>
<P><FONT SIZE=3D2>-----Mensaje original-----</FONT>
<BR><FONT SIZE=3D2>De: Richard Greenwood [<A =
HREF=3D"mailto:rich at greenwoodmap.com">mailto:rich at greenwoodmap.com</A>]<=
/FONT>
<BR><FONT SIZE=3D2>Enviado el: martes, 27 de julio de 2004 4:03</FONT>
<BR><FONT SIZE=3D2>Para: Javier Castillejo Montes</FONT>
<BR><FONT SIZE=3D2>CC: mapserver-users at lists.gis.umn.edu</FONT>
<BR><FONT SIZE=3D2>Asunto: Re: [Mapserver-users] JBOX ERROR and =
more</FONT>
</P>
<BR>
<P><FONT SIZE=3D2>Javier Castillejo Montes wrote:</FONT>
</P>
<P><FONT SIZE=3D2>> Hi all!</FONT>
<BR><FONT SIZE=3D2>> </FONT>
<BR><FONT SIZE=3D2>> I'm using jbox and it works almost perfect. =
Sometimes(i don't know when) I</FONT>
<BR><FONT SIZE=3D2>> have "Applet error. IOException =
PngImage" error, but I just clic where the</FONT>
<BR><FONT SIZE=3D2>> map is suppose to be drawn and it's appears =
with oput any problem... Does</FONT>
<BR><FONT SIZE=3D2>> anyone know how to avoid this error?</FONT>
</P>
<P><FONT SIZE=3D2>I would love to help with any jBox problems, but you =
need to give us a </FONT>
<BR><FONT SIZE=3D2>better idea of when the problem occurs and the code =
that causes to to </FONT>
<BR><FONT SIZE=3D2>happen. For example, what browser? what Java Virtual =
Machine (VM)? Does </FONT>
<BR><FONT SIZE=3D2>it happen right when the pages has loaded, or after =
many zooms and pans?</FONT>
</P>
<P><FONT SIZE=3D2>> I asked the next question some time ago as I =
couldn't solve the promen I</FONT>
<BR><FONT SIZE=3D2>> just aboid the step, but now my boss ask me =
about to add this step so...</FONT>
<BR><FONT SIZE=3D2>> here it is the question, as I couldn't solve it =
yet... I have a map country,</FONT>
<BR><FONT SIZE=3D2>> and it has been divided into small parts. Its =
parts should have been drawn</FONT>
<BR><FONT SIZE=3D2>> with different colors... as I can find =
differents parts in differents</FONT>
<BR><FONT SIZE=3D2>> countries I would like to know how to set for =
each part a color.</FONT>
</P>
<P><FONT SIZE=3D2>You are more likely to get an answer to this question =
if you post it as </FONT>
<BR><FONT SIZE=3D2>a separate email with an appropriate subject.</FONT>
</P>
<P><FONT SIZE=3D2>Regards,</FONT>
<BR><FONT SIZE=3D2>-- </FONT>
<BR><FONT SIZE=3D2>Richard Greenwood</FONT>
<BR><FONT SIZE=3D2>www.greenwoodmap.com</FONT>
</P>
</BODY>
</HTML>
------_=_NextPart_001_01C473A3.F084C2F4--
