[Mapserver-users] Labeling question {Scanned}
Siki Zoltan
siki at agt.bme.hu
Tue Jul 27 16:06:25 EDT 2004
change status to ON or DEFAULT,
the type should be ANNOTATION not point
Bye
Zoltan
On Tue, 27 Jul 2004, Zamil Murji wrote:
> Hello,
> I tried the TEXT option for a class, but it doesn't do anything. Here is the offending layer:
> LAYER
> NAME "rasterlogs"
> TYPE point
> STATUS off
> MAXSCALE 800000
> CONNECTIONTYPE postgis
> CONNECTION "user=idc dbname=idc host=idcmap port=5432"
> DATA "the_geom from main_well1"
> FILTER "raster_log = 'Y'"
> CLASSITEM uwi
> CLASS
> # COLOR 255 0 0
> # SYMBOL 6
> # SIZE 11
> TEXT "5"
> LABEL
> COLOR 0 0 0
> TYPE TRUETYPE
> FONT wells
> FORCE on
> SIZE 12
> POSITION cc
> MAXSIZE 12
> MINSIZE 12
> END
> END
> PROJECTION
> "init=epsg:4269"
> END
> END
> If I comment the TEXT and LABEL and uncomment the symbol then everything works fine. Right now it is bringing back a blank image.
> Any thoughts?
> Zamil
> -----Original Message-----
> From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
> Sent: Monday, July 26, 2004 11:11 PM
> To: Zamil Murji; mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Labeling question
> There is a TEXT option for a class that sets a static label to be used
> for all features in that class. That way you don't need a labelitem.
> Steve
> >>> "Zamil Murji" <Zamil.Murji at divestco.com> 07/26/04 4:52 PM >>>
> Hello list,
> I am currently using a symbol to display a postgis layer. I want to give
> the user the ability to display any character from a special font file
> that we have. Is there a way to force a layer to display a certain
> character.
> I know you can do LABELITEM and give it a column in the db to reference
> for the character (this works btw), but I want to write it into the map
> file so that it is easy to change. I also don't want to have 500000
> redundant rows because if I have to change that character then I have to
> write an update function instead of just changing the .map file.
> Any ideas?
> Zamil
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
