[Mapserver-users] solved: Logical expressions in CLASS EXPRESSION
Sean Gillies
sgillies at frii.com
Tue Jul 27 14:23:30 EDT 2004
On Jul 27, 2004, at 6:05 AM, Stefanie Weykam wrote:
> Big surprise!
> I stripped everything down to the very essential, even the comments
> behind
> the EXPRESSION (where I kept all the expressions that I had tried so
> far) -
> and there it was!
> Remember:
> EXPRESSION ([Riq50] <=1) didn't show while EXPRESSION '1' did
> Problem identified:
> Any #comment which contains brackets and parenthesis makes the
> expression
> fail (is apparently not understood as comment) unless the expression
> itself
> does not contain any brackets and parenthesis.
> For example:
> EXPRESSION ([Riq50] >1) # ([Riq50] >1) - fails
> and
> EXPRESSION ([Riq50] >1) # ('[Utm50km]' = 'VH4') - fails
> while
> EXPRESSION '1' # ([Riq50] >1) - is OK
> and
> EXPRESSION ([Riq50] >1) - is OK
> In the first two cases there are parenthesis and brackets, both in the
> expression and in the comment.
> So, this is it. Funny thing.
> cheers,
> Stefanie
Please report this in the mapserver issue tracker, it's the only
reliable
way to get attention of developers and get it fixed.
http://mapserver.gis.umn.edu/bugs/enter_bug.cgi
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
