[Mapserver-users] Oracle Spatial Extents
Frans Knibbe
frans at geodan.nl
Tue Jul 27 04:44:17 EDT 2004
Vladimir,
Ah, I understand now, you want the MBR of the entire table/layer, not of
every single geometric object...
It is strange that SDO_AGGR_MBR also takes too long, I would expect it
to execute faster. Have you also tried SDO_TUNE.EXTENT_OF?
Are your data often modified? If the geometric data are not changing,
you could also queryuser_sdo_geom_metadata, because the extent of the
entire layer is stored there.
Did you update user_sdo_geom_metadata after projecting the data?
You were right about your data not being geodetic. The difference is
that geodetic co-ordinates indicate a point on a sphere or sphere-like
object, whereas projected co-ordinates generally indicate a point on a
flat surface. The first co-ordinate system you used (SRID 8307) was
geodetic, and that is why you weren't able to use the MBR functions. You
can tell whether a co-ordinate system is geodetic by looking at the
tabel MDSYS.CS_SRS. The column WKTEXT holds the Well Known Text
description fort each SRID. If it starts with "GEOGCS", the co-ordinate
system is geodetic.
Good luck,
Frans
> Hi, Frans.
> It takes 29 secs to get the full extents of the geometry, which has
> ~2500 elements.
> The oracle gets all the ~2500 extents, and then gets the minimum and
> maximum value for X and Y, so I obtain the full extents this way.
> I'm using Oracle Spatial 9i.
> My data is not geodetic (SRID=1=>Sinusoidal WGS84)
> I don't understand very well the difference between geodetic and
> non-geodetic data, anyway, at the beginning I had my data in SRID=8307
> and I wasn't able to use the MBR functions, so I switched to SRID=1.
> And trying the Fernando Simon's suggestion
> (http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0407/msg00767.html),
> I had no luck.
> The level with SDO_TUNE.ESTIMATE_TILING_LEVEL was 6, but the query
> didn't get better. Besides, after indexing this way I wasn't able to
> draw the geometry outside the extents.
> My question now is: Is there another way to get the extents of a
> geometry?
> I also tried SDO_AGGR_MBR with the same results (too much time
> executing the query).
> The point is that I use a lot this functionality in Postgis
> (extent(the_geom)) with very large datasets and Postgis does it very
> fast.
> Any help will be very appreciated.
> Thanks a lot in advance,
