[Mapserver-users] Mapserver performance for large maps - suggestions?
Nick Johnson
arachnid at notdot.net
Wed Jul 28 06:17:00 EDT 2004
I'm installing and configuring Mapserver for use in a geo-located photo
album. I'm currently converting the vmap0 maps from their format into
shapefiles with ogr2ogr so I can use them, and have a few questions
about how to obtain the best performance:
- Should I merge all 4 regions of a particular layer into one file, or
is there a benifit to keeping them seperate?
- Am I likely to encounter performance issues with such large layers?
(The largest will be ~500MB - though I may not use it - the average
probably around 30-60MB) If so, how can I improve performance? I'm aware
I should have lower detail maps for wider views, but what can I do
beyond that?
- Will loading the maps into PostGIS give an improvement in performance?
I'd read somewhere that shapefiles are slightly faster than postgis for
simple geographical queries - is this the case for large amounts of data
such as this?
- What other things can I do to improve performance considering the
amount of accessible map data?
Thanks,
Nick Johnson
