[Mapserver-users] Join definition problems
Richard Greenwood
rich at greenwoodmap.com
Wed Jul 28 17:33:03 EDT 2004
Mark Adams wrote:
> Im having trouble with retrieving data from joins between a shape file
> and 2 DBFs with related data. Im not getting any errors, but MapServer
> does not seem to be returning any data from the joins either. Im not
> 100% sure about the join syntax as there is conflicting (and sparse)
> information on the web about this. Can someone tell me if Ive got
> something wrong? Were using MapServer and PHP MapScript 4.2, and not
> using templates. THX
I use joins with CGI, not MapScript, so I don't understand how you are
retrieving the data, but I know you do have to prefix a joined field
name with the join name. For example, if your WWR table had a field
named DEPTH, then using your join named "wwr" you would access the
DEPTH filed as wwr_DEPTH.
Regards,
Richard Greenwood
www.greenwoodmap.com
