[Mapserver-users] Mapobj between severals php scripts
Stéphane RIFF
stephane.riff at cerene.fr
Fri Jul 30 10:41:35 EDT 2004
In fact i want to use the same mapObj in two script. This two script are
in two different frame
and i want to use the map object in the two script. I tested with php
sessions but it doesn't work, i tried with $map->save('filename')
but this doesn't store the query result so i ask your advices
Hope this one is more explicit
Thanks
Merlos wrote:
>Your question is not very explicit. What do you mean with share?
>Maybe you are not referring to this, but, in general, if you define a
>variable in the "main" function of a php script it is accessible in all
>included scripts or using the global keyword in functions, but this is
>something general on the php language, it is not a particularity of the
>phpmapscript.
><?php
>//first.php
>//Define the map as global
>$map = ms_newMapObj('mymap.map');
>include ('second.php');
><?php
>//second.php
>function mydraw () {
> global $map;
> $img= map->draw();
>$ext = $map->getExtent();
>mydraw();
>On Friday 30 July 2004 14:36, Stéphane RIFF wrote:
>>Hello
>>I want to know if it's possible to share a map object create with
>>phpmapscript between multiple script ???
>>Thanks
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
