[Mapserver-users] Examples of simple map services with python mapscript?
Sean Gillies
sgillies at frii.com
Fri Jul 30 12:37:47 EDT 2004
On Jul 30, 2004, at 10:13 AM, William Hudspeth wrote:
> Sean Gillies wrote:
>> On Jul 29, 2004, at 3:04 PM, William Hudspeth wrote:
>>> Does anyone have some simple examples of using python mapscript to
>>> display a map service?
>>> Thanks, Bill
>> Bill,
>> At the 2004 MapServer Users Meeting and Open Source GIS conference I
>> did a
>> workshop using Python mapscript. The workshop web page is
>> http://users.frii.com/sgillies/projects/mum04/workshop.html
>> and has some examples. One includes a lightweight web server built
>> using Twisted, a Python web app framework. The other examples can
>> easily
>> be adapted to a web platform like Apache + CGI.
>> cheers,
>> Sean
> Thanks again for helping out Sean,
> I am trying to get the basics down before proceeding too far. I looked
> at your workshop scripts and power point demonstration, and am trying
> to just display a simple map. Using the code below, all of the
> mapscript functionality runs until the "save()" method:
> #start the map
> nmMap = mapscript.mapObj('/var/www/cgi-bin/python_test/nm_map.map')
> for i in range(nmMap.numlayers):
> nmMap.getLayer(i).status=mapscript.MS_ON
> #render the map
> map_image=nmMap.draw()
> map_image.save("first.png")
> map_div="""<DIV ID='mapdiv'><input ID='mapimg' TYPE='image'
> SRC='%s'></DIV>"""
> print map_div % "first.png"
> then I get an error:
> IOError: msSaveImage(): Unable to access file. (first.png)
> I suspect it has something to do with where or how I am storing my
> output image files, I just don't know. Any help greatly appreciated.
> Bill
Bill,
Here is my recommendation:
Lets say you have a location like /var/www/html/ms-tmp for mapserver
images
and that you make this directory accessible on the web by the url
http://HOST/ms-tmp.
In your script, you could define
ms_temp_dir = '/var/www/html/ms-tmp'
ms_temp_url = 'http://HOST/ms-tmp'
and then, when saving the image:
image_name = 'first.%s' % map_image.format.extension
image_path = os.path.join(ms_temp_dir, image_name)
image_url = os.path.join(ms_temp_url, image_name)
map_image.save(image_path)
print map_div % image_url
See how you can get the file extension from the imageObj?
Sean
Sean Gillies
sgillies at frii dot com
