[Mapserver-users] Building a legend - with class objects in l
ayers
Delfos, Jacob
jacob.delfos at maunsell.com
Tue Jun 15 04:59:12 EDT 2004
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_000_01C452B7.06D34B60
Content-Type: text/plain
Richard,
Have a look at http://mapserver.gis.umn.edu/doc/html-legend-howto.html
You can use the attached template to create a legend that will display
classes with their names.
Regards,
Jacob
-----Original Message-----
From: Richard Orchard [mailto:richard.orchard at ermapper.com.au]
Sent: Tuesday, 15 June 2004 4:42 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Building a legend - with class objects in layers
hi,
I am using mapserver to display some geology datasets.
A particular layer has multiple classes in order to show the various
features (different rock types). The features are color-coded, therefore, i
need each feature (class) to display in the legend.
However, when the legend is generated, it just creates one item, based on
the layer name. it doesn't iterate through the various class objects.
Is this the way it is supposed to work? Or is there a way to get it to
create a legend item for each class item within a layer. At present i am
creating new layer objects for each item i want to display. I have put the
map file i am using at the bottom of this email.
Thanks in advance,
Richard
---- mapfile
MAP
NAME "Australia - General Information"
STATUS ON
EXTENT 109.337 -44.387 158.742 -8.8081
SIZE 400 300
SHAPEPATH "D:\webs\www3\gis_data\australia"
SYMBOLSET "D:\webs\www3\mapserver\etc\symbols.sym"
FONTSET "D:\webs\www3\mapserver\etc\fonts.txt"
IMAGETYPE PNG
IMAGECOLOR 255 255 255
UNITS DD
# Start of web interface definition
WEB
MINSCALE 2e+06
MAXSCALE 5e+07
# On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the
root
# of the drive where the .MAP file resides.
IMAGEPATH "D:/webs/www3/temp/"
IMAGEURL "/temp/"
END
# Start of querymap object
QUERYMAP
STATUS OFF
SIZE -1 -1
COLOR 255 0 0
STYLE HILITE
END
# Start of legend object
LEGEND
STATUS ON
POSITION LL
KEYSIZE 18 12
KEYSPACING 5 5
TEMPLATE "ttt"
LABEL
TYPE BITMAP
SIZE MEDIUM
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 89
PARTIALS TRUE
FORCE FALSE
END
END
# Start of scalebar object
SCALEBAR
STATUS ON
COLOR 255 255 255
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 0 0 0
UNITS KILOMETERS
INTERVALS 5
SIZE 150 5
STYLE 0
POSITION LL
LABEL
TYPE BITMAP
SIZE SMALL
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
PARTIALS TRUE
FORCE FALSE
END
END
# Start of OutputFormat object
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE PC256
TRANSPARENT FALSE
END
# Start of layer definitions
LAYER
NAME "Roads"
STATUS ON
DATA "./roads/roads"
TYPE LINE
UNITS METERS
SIZEUNITS PIXELS
METADATA
"Description" "Test"
END
CLASS
NAME "Roads"
STYLE
SYMBOL 0
COLOR 220 0 0
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
END
LAYER
NAME "Earth Quake Risk 0.05 - 0.10"
STATUS ON
DATA "./earthQuakeHazard/eqriskdd"
TYPE POLYGON
UNITS KILOMETERS
SIZEUNITS PIXELS
METADATA
"Description" "Earth Quake"
END
CLASS
NAME "RISKVAL2"
EXPRESSION ('[RISKVAL]' eq '0.05 - 0.10')
LABEL
TYPE TRUETYPE
FONT "fritqat-bold"
SIZE 10
POSITION LL
OFFSET 0 0
END
STYLE
SYMBOL 0
COLOR 255 150 123
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
END
LAYER
NAME "Earth Quake Risk < 0.05"
STATUS ON
TYPE POLYGON
UNITS KILOMETERS
SIZEUNITS PIXELS
METADATA
END
CLASS
NAME "RISKVAL2"
EXPRESSION ('[RISKVAL]' eq '< 0.05')
LABEL
TYPE TRUETYPE
FONT "fritqat-bold"
SIZE 10
POSITION LL
OFFSET 0 0
END
STYLE
SYMBOL 0
COLOR 255 255 181
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
END
LAYER
NAME "Earth Quake Risk > 0.10"
STATUS ON
TYPE POLYGON
UNITS KILOMETERS
SIZEUNITS PIXELS
METADATA
END
CLASS
NAME "RISKVAL2"
EXPRESSION ('[RISKVAL]' eq '> 0.10')
LABEL
TYPE TRUETYPE
FONT "fritqat-bold"
SIZE 10
POSITION LL
OFFSET 0 0
END
STYLE
SYMBOL 0
COLOR 247 81 148
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
END
# Layer
END
This email and any files transmitted with it are confidential and intended
solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the sender
immediately and delete the original. Any other use of the email by you is
prohibited..
www.ermapper.com
www.earthetc.com
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: text/html;
name="printlegend.html"
Content-Disposition: attachment;
filename="printlegend.html"
[leg_class_html] <img src=[leg_icon] ALIGN='CENTER'><FONT SIZE=1 FACE="ARIAL"> [leg_class_name]</FONT><br> [/leg_class_html]
------_=_NextPart_000_01C452B7.06D34B60--
