[Mapserver-users] Pdf output shows junk on the browser?
Antti.Roppola at brs.gov.au
Tue Jun 15 04:38:24 EDT 2004
Hi Mahalakshmi,
What you are seeing appears to be a PDF file. Some things to try:
- Save it to a file and try opening the file with Acrobat
(to confirm that it is a valid PDF)
Yes, to answer your question, you can save the generated PDF as a
file, I do it by calling Mapserver as a system call and capturing
the output to a file.
- Grab the saved file and echo it as a download:
<?php
$file="/path/to/mypdf.pdf";
$handle=fopen($filename, "r");
$buf=fread($handle, filesize($filename));
$len = strlen($buf);
Header("Content-type:application/pdf");
Header("Content-Length:$len");
Header("Content-Disposition:inline; filename=my_map.pdf");
echo $buf;
fclose($buf);
I just tested this using IE 6.0 and Mozilla 1.x, while Mozilla
recognises the stream as a PDF and asks me if I want to open it
in xpdf or to save the file, IE just echoes the contents of the
PDF (as shown in your email)
- Save the created PDF to the web-server and send the user a
URL to click on. I tried this, and IE handles that OK.
Aka, it seems to be something broken about how IE recognises PDFs
in general. A quick look arounf IE doesn't reveal anything like
the "helper applications" in Mozilla that lets you see how incoming
mime-types are handled.
Cheers,
Antti
-----Original Message-----
From: Mahalakshmi Narayanan [mailto:mhln25 at yahoo.com]
Sent: Tuesday, 15 June 2004 2:54 PM
To: Antti.Roppola at brs.gov.au; EZS at DeStraat.NL;
mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] Pdf output shows junk on the browser?
Thanks for the reply..
However, my problem is still unresolved..
The junk starts with ...
%PDF-1.3 %äãÏÒ 5 0 obj <> stream xoe3T0BC 650PHÎå2 èB(
ß)"ËH!¤^Ë5" ´!pendstream endobj 6 0 obj 40 endobj 7 0
obj <>] /Length 8 0 R >> stream
ÿØÿàJFIFÿþ;CREATOR: gd-jpeg v1.0 (using IJG JPEG
v62), quality = 95
ÿÛC
ÿÛC
ÿÀô"ÿÄ
ÿĵ}!1AQa"q2'¡#B±ÁRÑð$3br'
%&'()*456789:CDEFGHIJSTUVWXYZcdefghijstuvwxyzf"...??^?S'""*--~(tm)s¢£¤¥¦§¨©ª²³´µ¶·¸¹ºÂÃÄÅÆÇÈÉÊÒÓÔÕÖ×ØÙÚáâãäåæçèéêñòóôõö÷øùúÿÄ
ÿĵw!1AQaq"2B'¡±Á #3RðbrÑ
$4á%ñ&'()*56789:CDEFGHIJSTUVWXYZcdefghijstuvwxyz'f"...??^?S'""*--~(tm)s¢
I visited all sites suggested by Emil Zegers, but not
still solved..
I have windows xp with acrobat reader 6 installed. My
ie settings seem to be ok 'cos I am able to open other
pdf documents.. I don't know how to save as pdf
document using map file itself (from command prompt)
then try to open it.. is it possible to do that?
Thanks again..
With kind regards,
--- Antti.Roppola at brs.gov.au wrote:
> What sort of junk?
> If it looks like this, you are getting a PDF file,
> but it is not
> being recognised by the end-user as one:
> %PDF-1.3
> %äãÏÒ
> 5 0 obj
> <</Length 6 0 R
> /Filter/FlateDecode
> stream
x~\~D½I²$I®$¸~OS¼^K´~SÌö~Iê^Fu^BëEmÂ6ÿþ~K^F3CÌó©À²èS~÷~@«ªÉ~H~Q^Aä~_
> I have noticed that the PDF output file includes a
> MIME header
> in the first couple of lines. Depending on how you
> are generating
> and sending the file, this might be a problem. If
> so, try open the
> PDF file and delete everything before "%PDF-" before
> sending it to
> the browser. Also try opening the file from your PDF
> reader. Aka,
> the first thing to do is confirm that a valid PDF
> file is being created.
> Cheers,
> Antti
> From: Emil Zegers [mailto:EZS at DeStraat.NL]
> Sent: Friday, 11 June 2004 5:38 PM
> To: mapserver-users at lists.gis.umn.edu;
> mhln25 at yahoo.com
> Subject: Re: [Mapserver-users] Pdf output shows junk
> on the browser?
> Hello
> If your PDF configuration in the map file is correct
> and you do have installed Adobe Acrobat and/or
> Reader, the problem might be caused by some browser
> related issues.
> Especially recent IE versions have trouble
> displaying server side (created) PDF's properly.
> Take a look at the following links for more info:
> http://www.adobe.com/support/techdocs/29776.htm
http://forum.planetpdf.com/wb/default.asp?action=9&fid=6&read=41191
> http://www.bnl.gov/itd/webapps/pdf_help.asp
> Groeten,
> Emil Zegers
> De Straat Milieu-adviseurs
> Divisie Informatisering
> 026 7513902
> 06 22965585
> http://www.destraat.nl
> >>> Mahalakshmi Narayanan <mhln25 at yahoo.com>
> 06/11/04 08:09 AM >>>
> Hi!
> I tried to output my map as a pdf but I get junk
> thrown to me when I include the following
> outputformat
> tag..
> OUTPUTFORMAT
> NAME pdf
> MIMETYPE "application/x-pdf"
> DRIVER pdf
> # FORMATOPTION "OUTPUT_TYPE=RASTER"
> EXTENSION "pdf"
> END
> I am running windows xp with
> MapServer version 4.0.2 OUTPUT=GIF OUTPUT=PNG
> OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
> OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLI
> ENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> do i need anything else to be installed on my box to
> get pdf output?
> can somebody help me, pls.
> With regards,
> __________________________________
> Do you Yahoo!?
> Friends. Fun. Try the all-new Yahoo! Messenger.
> http://messenger.yahoo.com/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> __________
> VChecked
______________________________________________________
> This message has been checked for all known viruses
Do you Yahoo!?
